2003 Tahoe-grumbling/roaring when turning left issue
jbres
I own a 2003 Tahoe with 153k and when I turn left at low speeds I keep hearing a grumbling/roaring type noise. When I turn right, doesn't make noise at all. Also, when vehicle is parked and I turn it left, IT DOES NOT make that noise.
It almost sounds the same as if its in 4wd and your trying to turn, but that's not the case.
Any suggestions?
Thanks!
9 REPLIES 9
B_O__Plenty
Campfire Time wrote:
Classic symptoms of a failing wheel bearing hub. You're lucky it went as long as 153k. GMs are notorious for failed WBs at around 100k. I replaced both WBs in my HHR, my Sierra, and on my old Trailblazer.
And if one is failing, the other will not be far behind. So replace both and save a later headache. If you are handy you can do this yourself and save about $200 in labor for each hub (yes, each). As said above it's not too hard and there are plenty of you tube videos on how to do it.
That's my guess. If you aren't sure bring it someplace and get an expert opinion. It costs a lot of $$ to just throw parts at it based on opinions gotten from the internet.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
jbres
So I jacked the Tahoe up, and when I wiggle it side to side I am getting just a little play with a little noise.. For sure sign of wheel bearing bad?
Campfire_Time
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
2003silverado
Sounds like wheel bearing to me as well. Jack up the front and see if you can wobble the wheel at all. If it is the bearing its a pretty easy job to replace yourself if you have the proper tools.
jhlady
Check for tire rub on the left side inner fender well. Did you put new tires or wheels on recently? Could result in a rub where previously there wasn't one.
Hope this helps.
naturist
Wheel bearing would be first guess; if 4WD/AWD, it'd likely be a bad CV joint. Either way, get it fixed before the wheel falls off. Really.
jbres
wheel bearing?
3oaks
donn0128 wrote:
Bad bearing would be my first guess.
Yep, my guess too. When turning the wheel while parked, the bearing isn't rotating to make that sound.
donn0128
