Dec-31-2015 05:11 AM
Jan-02-2016 08:07 AM
Campfire Time wrote:That's my guess. If you aren't sure bring it someplace and get an expert opinion. It costs a lot of $$ to just throw parts at it based on opinions gotten from the internet.
Classic symptoms of a failing wheel bearing hub. You're lucky it went as long as 153k. GMs are notorious for failed WBs at around 100k. I replaced both WBs in my HHR, my Sierra, and on my old Trailblazer.
And if one is failing, the other will not be far behind. So replace both and save a later headache. If you are handy you can do this yourself and save about $200 in labor for each hub (yes, each). As said above it's not too hard and there are plenty of you tube videos on how to do it.
Jan-01-2016 09:03 AM
Dec-31-2015 10:08 AM
Dec-31-2015 09:52 AM
Dec-31-2015 08:53 AM
Dec-31-2015 06:43 AM
Dec-31-2015 05:29 AM
Dec-31-2015 05:28 AM
donn0128 wrote:Yep, my guess too. When turning the wheel while parked, the bearing isn't rotating to make that sound.
Bad bearing would be my first guess.
Dec-31-2015 05:23 AM
