Well just to document the final end of my story here. As stated earlier my Expedition came with the heavy duty towing package with a 4 pin plug minus the 7 pin plug. Of course, I do have a 7 pin plug, but the installation is definitely not factory. It was obvious that the factory 4 pin harness was installed with the blue brake wire taped up inside the loom. The 7 pin harness was spliced into the wiring with crimp connectors without a charge wire.
Since several respondents have cautioned that I may not have the heavy duty towing package, I have done the following:
1. I verified I have the 7A095 auxiliary transmission cooler.
2. I verified I have the 3D746 power steering cooler.
3. I verified I have the 8005 Radiator, which is the only one available for 06.
4. I have added a Scan gauge and programmed it to monitor the tranny temperature.
5. I have added a 12 gauge charge line by tapping into the 12 gauge orange wire under the drivers door attached to the frame (yeah I know it should have been 10 gauge).
6. I have added a 30 amp fuse and relay to the passenger side kick panel fuse box in the trailer charge wire positions.
7. I need to have the tranny fluid changed - as it is original most likely.
Once No. 7 is complete and I get some free time from work, I am ready for some heavy duty hauling and camping.
Jerry
2016 Gulfstream Ameri Lite 268BH
2006 Ford Expedition
