โNov-01-2019 11:23 AM
โNov-04-2019 05:14 AM
ShinerBock wrote:goducks10 wrote:ShinerBock wrote:
There are also many fanboys here who do not like to tell the truth because it makes their favorite brand look bad. They are usually easy to spot because they will focus only on the bad of other brands and refuse to believe there is anything bad with their favorite brand. They also usually exaggerate numbers so take what they say with a grain of salt just as you would with a fanboy of an opposing brand.
Your post at first sounded Fishy to me. But then again I'm Cummins to believe you're on to something. ๐
LOL!!!!
โNov-04-2019 04:45 AM
โNov-03-2019 07:49 AM
โNov-03-2019 06:57 AM
โNov-03-2019 05:53 AM
โNov-02-2019 07:28 PM
โNov-02-2019 06:00 PM
โNov-02-2019 05:55 PM
โNov-01-2019 08:57 PM
โNov-01-2019 07:16 PM
klr650goldwing wrote:
I'm looking to buy a 2012 f350 super duty 6.7 TD CC LB 4X4. I'll be pulling a 12,500 lb. 5th wheel trailer. My question is how many miles is too many for this truck? I'm new to diesels and from what I've heard diesels last longer than gas engines, but with no personal experience, I need some help from you diesel experts. If you were buying this truck how many miles would cause you to shy away from the truck?
โNov-01-2019 05:52 PM
Lynnmor wrote:Turtle n Peeps wrote:
Preventing catastrophic engine failure. Change those early glow plugs boys.
Now that I'm at it, I didn't mention valve cracking problems.
I also was remiss in not mentioning the tons of turbo failures they had.
Interesting that Ford fixed ALL of these problems later on. The valve issue were listed up the 2015 in their TSB's. Pretty telling.
The glow plug clown is in error.
The cracked valve problem was poor heat treating and corrected on trucks produced after 3/28/2011.
The TSB you are referring to, I believe, was a noise problem addressed by a customer advisory on how to operate a diesel.
The ceramic turbo bearings did have a higher failure rate than later steel bearings.
AERA wrote:
The AERA Technical Committee offers the following information on a rough running or engine misfire on 2011-2016 Ford 6.7L diesel engines.
Ford wrote:
TSB 16-0041
PICKUP - 6.7L DIESEL ENGINE - RUNS ROUGH DURING EXHAUST REGENERATION PROCESS - BUILT ON OR BEFORE 2/23/2016
[************]Publication Date: March 7, 2016
FORD: 2015-2016 F-250, F-350, F-450
This article supersedes TSB 15-0106 to update the Issue Statement, Service Procedure and Part List.
ISSUE:
Some 2015-2016 F-Super Duty 250-450 Pickup vehicles equipped with a 6.7L diesel engine and built on or before 2/23/2016 may exhibit a runs rough/misfire condition only during the exhaust regeneration process. This condition typically occurs on light throttle tip in between 64-113 Km/h (40-70 MPH) and will not set diagnostic trouble codes (DTCs). The concern may be intermittent and a knocking noise may be present during the concern. ACTION:
โNov-01-2019 05:14 PM
โNov-01-2019 03:19 PM
โNov-01-2019 02:27 PM
โNov-01-2019 01:43 PM
