2012 Freightliner M2-112
R12RTee
I'm looking at a 2012 Freightliner M2-112 with the Detroit 13 Liter (DD13) rated at 505HP/1800TQ. Is anyone familiar with this engine? I'll be pulling a 20K fifth wheel camper with it. It seems that it will be plenty powerful enough for the mountains but how about fuel mileage? Anyone drive one?
2021 DRV Mobile Suites 38RSSA
2021 Ram 6.7 HO
33 REPLIES 33
aarondeere
Or you could go with this. 13L 505hp/1750tq 12 speed automated manual with no clutch pedal. No problems with any fifth wheel.
Aaron
2010 Dodge 3500
2012 Voltage 3600 Epic
Mike_Up
My sister has an 8 horse trailer that's also an RV with a changing room inbetween the RV section and horse trailer section. They kept burning up F350 transmissions so they got this truck. Unfortunately the maintanence cost was so high, it forced them to go to a F450 instead.
2019 Ford F150 XLT Sport, CC, 4WD, 145" WB, 3.5L Ecoboost, 10 speed, 3.55 9.75" Locking Axle, Max Tow, 1831# Payload, 10700# Tow Rating, pulling a 2020 Rockwood Premier 2716g, with a 14' box. Previous 2012 Jayco Jay Flight 26BH.
recycler
the M-2's are a comfortable truck though i would get one with an auto.. friends i work for now and then have one with the auto shift manual the control system for the clutching and shifting went out was fairly expensive to have repaired.. gets better milage than the f350 crew cab it replaced hauling the same weight.. both have towed over 30,000lbs.. also turns alot sharper..
1999 F550 truck conversion
thomasmnile
2oldman wrote:
That sounds more like a Class 8 tractor rating. I think 1800 is a bit overstated.
DD13 Spec Sheet
According to the spec sheet, the OP is a little high on both HP & TQ ranges, but still respectable numbers.
EDIT: There is another spec sheet on Detroit's website with this engine offered in a Freightliner Class A DP chassis. It's rated at 500 HP and 1650 ft/lbs TQ. Might be what the OP was referring to.
2oldman
john_bet
hone eagle wrote:
Look at your typical school bus driving lady,older grandma type.
I drive both and my tractor is infinitely easier to drive,turns much tighter then my old F250 and the trailer is a lot simpler to back with the hitch behind the drive axle.
The only major issue could be the height .
Agree on bus drivers. Over 50% of the drivers in my county are ladies'. Most of those own the buses.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
hone_eagle
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
JN_B
I live very close to Spruce Meadows http://www.sprucemeadows.com/ and on any weekend I see ladies driving these trucks in places that's very busy and not alot of room to maneuver. They must be easy to drive.
If only I could afford one.
2014 Ford F-150 XLT, HD Payload, Max Trailer
2010 K-Z Spree 318BHS
mpierce
My wife is 5'0". Drove team with me pulling a reefer from MN to CA every week hauling produce. Sure got some looks when she climbed out of the drivers seat of that long nose Peterbilt, pulling a 53" Reefer!
carringb
The sight-lines on the M2 are so much better than any of the full-size pickups, I suspect even mommy-mobile-driving women would not be intimidated once they got behind the wheel. The bigger mirrors and sharper turning should help too.
Just be sure you wear your seatbelt for the first drive, because I guarantee she will give it much more brake pedal than she needs too!
2014 ORV really big trailer
2015 Ford Focus ST
benalbert
Depends on the wife. Mine has her CDL. :C
08 F350 CCLB SRW 6.8
00 KZ Sportsmen 951
hone_eagle
Wife drives ours no problem ,no clutch peddle no shifting.
Easy pesy
Newmar 34rsks 2008
aemedic
cabanaman wrote:
Turtle n Peeps wrote:
I prefer the higher ride position, giving better visibility. The ride is better with the air ride cab and air ride seats. The M2 turns sharper than my Ford F-350.
Wow, lets see.
Better fuel mileage than a pickup. Check
Better visibility than an pickup. Check
Better ride than a pickup. Check
Turns sharper than a pickup. Check
Way better range than a pickup. Check
Sounds the same as my buddies class 8 Volvo. If I ever get money up I may have to check into one of these. ๐Ÿ™‚
Will the wife drive it? Uncheck:(
Ah, but due to the auto she could make it move in an emergency if she had to...
Chris
2004 Bluebird Wanderlodge M380
cabanaman
Wow, lets see.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake. Emissions removed.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
