2014 Ford 6.7
brooks379
This might not be the right forum but.....Does the sensor that tells when to change your motor oil change when you run a different oil than what the truck came with ?
I changed the oil at 5000 miles and started using Shell Rotella T-6 5 w 40 full syn. The 5 w 40 has 7000 mi on it and the info center is telling me to change oil soon which I will. Just wondering if I was using Ford oil how many miles until I got the change oil soon message....More or less miles or does the sensor determine it? Guess I'm wondering how that works.
If it is standard now days to go 5000 to 7000 miles on conventional oil I thought I could get about 8ooo mile with a full synthetic oil.
20 REPLIES 20
skyhammer
On my Ford, in the DIC there is a setting you can pick for towing. There is not much of an explanation on how it works, other than saying it changes the distance to empty calculation.
I was just in the truck and the Distance to empty said 500 miles in the non towing mode. When I switch to towing mode(in the DIC), the Distance to empty dropped to 375 miles.
I have never remembered to change to tow mode when I tow, so I can't say what difference it makes.
I do wonder if setting the DIC to tow mode changes anything else such as when the oil change message appears.
2011 Host Everest, 11.5',triple slide.
2011 F-350,DRW,CC,LWB,4X4,6.7
SkiSmuggs
The algorithm takes the type of driving into account. Short trips mean shorter oil life as it doesn't get hot enough to burn off pollutants. Long highway trips are much easier on the oil. With towing, I assume any too hot conditions might shorten oil life, but typically not stop and go, so not that bad.
With my truck, the default is about 10K miles, but I reset it to 70% which would warn me at about 7000 miles.
2015 F350 XLT PSD 6.7 Crew Cab, Andersen Ultimate hitch
2012 Cougar High Country 299RKS 5th wheel, Mor/Ryde pinbox, 300w of solar
Cummins12V98
Gary66 wrote:
If your doing a lot of towing the computer is taking this into account ( assuming your using the Tow/Haul mode)and will prompt you to change the oil sooner than if you were normal driving.
Totally disagree! I get the longest oil changes when doing mostly towing. At or near 7,500 miles. When towing for hours on end the engine has very few regens and little wear compared to stop and go.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
The_Mad_Norsky
Double posting, sorry!
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
The_Mad_Norsky
FishOnOne wrote:
It's obvious that the manufacturers don't require an early oil change during the break in period which I don't agree with; therefore I usually do the first oil change at 3,000 - 3,500 miles.
Well said. Agree 100%.
If memory serves me, my previous vehicle (Ford w/6.7L diesel) always showed the oil change reminder around the 7,500 mile mark. No matter what oil viscosity was used in it. (the 10W/30 or 5W/40 diesel oils).
RV'ing since 1991
N-Trouble
Most of the new trucks with integrated brake controllers know when a trailer is attached regardless of using tow/haul.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
FishOnOne
ib516 wrote:
I'm having trouble stretching the oci out as long as the computer says to go in my 2014 Cherokee Trailhawk and the 2014 Ram 2500 with the Hemi. Both say they will go about 9000 miles or so. I've been changing the oil at about 5000-6000 miles on each. That said, I've only done one on the truck and two on the Jeep.
I guess I should get off my wallet and send a sample of each into Blackstone to see how it is actually doing.
Blackstone testing should confirm your OLM limits of ~9k miles and build confidence, but it's hard to resist the urge to drain the used oil and put fresh oil back in. IIRC your Hemi takes a 0W40 weight oil and I definitely would test to ensure the viscosity stayed in grade.
In a weird kind of way I actually enjoy changing the oil on my truck. :h
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
goducks10
That's opposite of my Ram CTD. I don't need DEF so I regen more often. When towing the trucks running more constant at hwy speeds vs running around town with stop and starts.
ib516
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
FishOnOne
I don't follow the OLM on my Super Duty and prefer to change the oil a bit earlier even when using Shell Rotella T6 5W40 synthetic.
On my wife's '11 Ford Edge I would follow the OLM in which it would go 10k miles on a oil change and the oil was still a honey color.
I just changed the oil on my wife's new '14 Ford Edge Sport this morning at 3k miles, and then I'll change oil at another 5k miles and then I'll go with the OLM which as of this morning said 72% oil life remaining so I'm certain it will be on a 10k mile OCI also.
brulaz
I've wondered about this.
But even towing over 50% of its miles (7500# in T/H), the oil monitor still lets me run up close to 16,000 km (10K miles) on the EcoB.
Think ratio of hwy to idling miles may be more important, as 95% of my driving is hwy.
Anyway, I've switched to full synthetic as only spending Can$60 every 16K kms on maintenance is ridiculous.
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
ib516
Clicky - how oil life monitors work
mich800
brooks379 wrote:
Sport45 wrote:
The OLM system may be conservative for some oils. But you may risk your warranty if you run it past the change oil warning indication or reset it without the receipts indicating the oil was changed.
I'm sure the vehicle computer logs those things.
I'm going to change the oil today. I'm sure if something was to go bad with the motor that's probably the first thing that would be looked at. If you reset it can it tell that there is new oil in the motor or is it just reset and starting over ??? Don't get me wrong I'm not trying to get out of changing the oil I will change it in a heart beat, just trying to learn this thing.
It is just a computer algorithm that measures various items between the reset such as miles, hours, etc. It cannot detect quality of oil, type, or if it has actually been changed.
brooks379
