2014 RAM 2500 6.4 burning through tires
samhain7
Hi all.
Want to get some opinions on this.
My 2014 Dodge Ram 2500 6.4 burned through the stock tires at 38,000kms (23,612mi).
I got pretty much from everyone that my driving was the culprit. For the record,
I drive like a grandma and even my wife gets annoyed by that.
I purchased (on reccomendation of the tire shop) Goodyear Duratrac tires.
9,000kms(5592mi) in on them, and the front wheels outer tread is ROUNDED. Like REALLY rounded. The engine side of both tires is fine.
I take the truck to the dealership and they suggest I need an alignment. Which I would like
to trust them until the guy said "Oh these 6.4 are famous for doing that to front tires".
So just like that, all credibility out the window. But I thought I would check here.
Is it possible that out of the cummins, the 5.7 and the 6.4 that only the 6.4 wrecks tires?
Any other suggestions would be great!
Thanks
Final notice from MasterCard. Good! I'm sick of hearing from them.
2016 Dodge Ram 2500 Cummins, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
25 REPLIES 25
BBFD
samhain7 wrote:
4X4, the original tires were firestones, the new tires are Goodyear Duratrac...
I don't have the axle weights...
36k on the truck in my sig and I had to replace my OE Firestones and that includes having two winters of snow tires. I don't think I got 30k out of them. My wife drives mostly highway with it and tires were rotated.
I tend to believe there is a relationship between tire life and what the factory decides to ship the truck with (cheapest possible tires)...
2013 Ram 3500 Crew Cab Laramie CTD
2017 KZ Durango 292BHT
Vanished
14k on my factory Firestone AT's and they are already almost shot.. Junk tires IMHO..
2019 Ford F350 4x4 diesel DRW
2021 Grand Design Momentum 28G
mowin
I was lucky to get 10k out of the stock Firestone AT. Got 25k out of a set of coopers. Just put another set of cooper's on a couple months ago. No abnormal wear on either set.
MerkelG
Factory specs for toe in is 1/4". Should be 1/32 and castor at 3.7 to 4.5 deg. Ask at turbo diesel register. Com.
jmtandem
Get to the alignment shop. I get 53,000 miles or so from a set of tires on my Ram and have the heavy diesel up front.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
45Ricochet
Different animal but my 06 Ram with the Cummins would round over front end tires on both inside and outsides. Lot of mountain driving though.
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Mmaxed
Find a competent alignment shop and get it fixed. My '15 6.4 does not eat tires on the front. They will be shot by 25k miles, but not because of a bad alignment.
samhain7
donn0128
Never heard of a gas burner eating tires. Must be something new.
BTW my OE tires were junk by 30K miles. Tires on wifes car lasted 23K miles and were done. Now, couple questions. Tread design? 4X4 or 4X2? Scaled weight on front and rear axles? How much off pavement driving do you do?
BTW, find a good alignment shop and have them go over it. NOT the dealership, but someone who specalizes in alignment work.
samhain7
More info, I do rotate every 10,000....should have added that....
djgodden
I have a 2012 4x4 Ram 2500 Laramie Longhorn with 6.7 Cummins. Never had that weird wear problem. IMHO, you need your alignment checked ASAP. I have 37,000 miles on mine, rotate regularly, alignment on the slightest indication of unusual wear. Big heavy truck will kill tires quickly.
2012 Ram 2500 4x4 Lariat Longhorn 6.7 CTD HO, Edge Evo CTS, Extreme Tow/Haul brakes, aFePower Diff cover, LL 5000 bags, 285/70R17, Reese Q20 w/slider. 2005 Montana 2955RL w/400w solar, Renogy MPPT, 4 x 6v @ 12VDC (450AH), 3000w Inverter, King VQ4100.
