โMar-18-2016 01:30 PM
โMar-20-2016 01:54 PM
โMar-18-2016 06:38 PM
RedRocket204 wrote:
The 2010 Sequoia has something like 9100 lbs tow capacity but the payloads do not match up for that rating.
โMar-18-2016 06:22 PM
camp-n-family wrote:
The Sequoia is a perfectly fine tow vehicle. Just like any other, as long as it is kept within its ratings. As with 1/2 ton based vehicles, you will be payload limited. I would aim to keep the loaded tt weight under 6k as long as you can handle the tongue weight. A hundred pounds over payload won't kill it. More important is to keep it under the axle and tire ratings.
The 5.7l with the 6speed is a bulletproof combo and will pull its rated weights in the mountains without problem. It will drop a few gears but don't be afraid to let it rev, won't hurt anything. It's best power is found above 3500rpm.
โMar-18-2016 03:14 PM
โMar-18-2016 03:02 PM
โMar-18-2016 01:54 PM
Bob Vaughn wrote:
Is a toyota sequoia platinum suitable as a tow vehicle for a travel trailer. It has a 7400 lb tow rating. My concern would be in the mountains of the west...
โMar-18-2016 01:33 PM
