2017 Ford F250 6.2 Gasser Radiator Drain
2_many_2
Deleted
21 REPLIES 21
BenK
Bryan is spot on...it is chemistry/laws of physics at work here
Add that is the main 'why' of the overflow bottle now being pressurized.
Using all of the kits out there creates yet, another O2 intrusion into the coolant system...that...works it dirty work over time. Sure, dependent on how much O2 gets in there...plus how much of the acid is left over from the etching/plating (acid etch's and the organic coats a protective layer)
Just leave it alone and 'check' via the translucent overflow bottle...there should be lines indicating 'max' and 'min' coolant levels
carringb wrote:
Honestly I'd leave it alone. The new coolants last a very long time as long as oxygen isn't introduced. You may inadvertently shorten the lifespan of your cooling system by periodically draining and filling. There's good reason why they've made it harder to service.
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Cummins12V98
FishOnOne wrote:
Cummins12V98 wrote:
FishOnOne wrote:
Cummins12V98 wrote:
agesilaus wrote:
At least on diesels they recommend checking the coolant annually. You can buy test strips from Amazon or the dealer will do it. At a cost of course.
NOT on the Cummins, Ford yes not so sure about the GM.
Yeah... OK
Cummins/Fleetguard Coolant Test Strips
Did I need to specify Cummins 6.7 does NOT need to use test strips???
No you didn't because the link I provided is for all cummins engines.
You could if you want but completely un needed. But please post a link from an owners manual that states antifreeze testing is needed on an 6.7.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
spud1957
So a thread asking about a drain plug on the rad of a Ford 6.2 gas turns into a discussion about testing antifreeze in a Cummins 6.7?
But no pictures?
Imagine that.
2018 F350 6.7 4x4 CCSB
2022 GD Reflection 337 RLS
FishOnOne
Cummins12V98 wrote:
FishOnOne wrote:
Yeah... OK
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
Cummins12V98
FishOnOne wrote:
Yeah... OK
FishOnOne
Yeah... OK
FishOnOne
agesilaus wrote:
FishOnOne wrote:
I would be really surprised if the radiator didn't have a drain plug. I do agree with theoldwizard that a 2017 truck should need a radiator fluid change. I changed mine on my '12 Power Stroke at ~100k miles. Currently have 153k miles and still have original water pump. The OAT fluid Ford installs is some high quality stuff.
Does your 2012 have a drain plug? I haven't found one on mine.
Yes it does.... It's located on the drivers side.
agesilaus
danrclem wrote:
I'm not sure if this applies to the 6.2 but might be worth watching. It shows where the drain is a little after 2 1/2 minutes.
https://www.youtube.com/watch?v=LZlbKb8hk30
Now that's interesting. A hidden drain petcock. I'll check out mine to see if it has one, the one on the video seems to be the 2011 1/2.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
danrclem
agesilaus
Superbumper
Cummins12V98
FishOnOne
theoldwizard1
Same on the gassers.
agesilaus
Superbumper
