May-02-2023 04:20 PM
May-03-2023 04:10 PM
May-03-2023 10:26 AM
May-03-2023 08:46 AM
May-03-2023 08:31 AM
jadatis wrote:ncladfw3 wrote:
Thanks for the replies. I got some more information off the tires:
- ST205/75/R15
- LH-001 (Maybe a Model# ?)
- 8PR 107/102L Load Range D
- Max Load Dual 850kg (1870lbs) at 450KPa (65PSI) COLD
It is a dual axle travel trailer, 6150lbs dry weight.
I'll probably try 65psi.
Do you mean by dual axle, 1 axle with 4 tire on it(verry unusuall, but they exist) , or tandem axle so 2 axles with each 2 tires on them.
And can you still read the GVWR and GAWR('s)
( Gross Axle/Vehicle Weight Rating)
May-03-2023 08:30 AM
May-03-2023 07:26 AM
May-03-2023 07:12 AM
May-03-2023 06:30 AM
ncladfw3 wrote:
Sorry, 2 axles with 2 tires on each axle.
May-03-2023 06:16 AM
May-03-2023 06:13 AM
- ST205/75/R15
- ST205/75/R15
May-03-2023 05:47 AM
May-03-2023 05:09 AM
May-03-2023 04:21 AM
May-03-2023 12:57 AM
