โJan-11-2015 02:30 PM
โJan-13-2015 07:31 AM
โJan-13-2015 07:14 AM
โJan-12-2015 04:28 PM
PawPaw_n_Gram wrote:
I had a Grey Wolf 26BH for a little over two years.
We strongly considered a Jay Flight 26BH but decided on the Grey Wolf.
What we didn't like about that size/ floor plan:
The jackknife sofa is a real pain to sit upon for more than a half hour. At that price point there are simply no comfortable sofas.
The bathroom is too small.
The dinette is a real pain because the heavy table top needs to be removed when you travel. Be sure to mount Velcro on the bottom of the table top and the edges of the seats. Otherwise it will come out into the aisle.
Too little storage for a trip longer than a weekend. Getting to anything under the sofa or the dinette seats was more work than it was worth. We ended up keeping a lot of stuff on the lower bunk simply to make it easier to get to.
No ducting on the AC. Ours was controlled by switches on the unit. It was too loud to talk while eating, or watch TV. Also ours would shut off the compressor if the temp go low enough, but would not shut off the fan. Constant noise.
We camped 24 nights with 4 or 5 grandchildren - needing every sleeping capability of the trailer, and 7 nights with my son - his wife and daughter.
Don't get me wrong - we had great times in the trailer, and it was a very good value. I'm just listing negatives - and they were mainly due to the floorplan and type of entry level trailer, rather than any issues from the manufacturer.
What we did learn from that TT was that we really loved RVing, and traveling, and we wanted to move to something bigger and full-time.
I also fully understand that most of us have to live with real world budgets and priorities - so price is very much a consideration.
I started towing the trailer - 4,850 lbs actual empty weight, 5,500 lbs loaded - with an F-150. The trailer could push the truck around if the wind was from the rear quarter and over 15 mph.
After a year, I got a Ram 2500 MegaCab - and it was a world of difference towing the trailer.
My personal opinion is that a trailer that size and weight is about the max to tow with a half-ton pickup.
โJan-12-2015 11:36 AM
โJan-12-2015 10:20 AM
โJan-12-2015 08:54 AM
โJan-12-2015 06:50 AM
โJan-12-2015 02:03 AM
โJan-11-2015 10:09 PM
opnspaces wrote:
You may get a lot of replies for and against each model. Just remember that aside from the actual house structure and maybe the frame and axles, all the trailers use the same parts from the same manufacturers. So a failed refrigerator, stove top, AC unit, converter/Charger, light fixtures, holding tanks, water pump, water heater, furnace etc, the manufacturers all use the same parts from outside vendors.
โJan-11-2015 10:00 PM
โJan-11-2015 09:16 PM
โJan-11-2015 09:14 PM
Doug1395 wrote:
Me and the family went to the the Cleveland rv show and have narrowed are new travel trailer search down to the basic 26bh models . There was jayco , colemen ,gray wolf and many others. After several hours they all were very similar and all with in 1000.00 dollars. Any and all opinions welcome.
โJan-11-2015 06:09 PM
โJan-11-2015 05:40 PM
