4x4 transfer caserepair
ford_coupe
Hope I,m not out of line with question here. can anyone recommend a 4x4 repair shop in michigan, blew transfer case to pieces on my03 dodge ram, thanks for any recomendations,apololigise if I, out of line here. john
10 REPLIES 10
ford_coupe
thanks for all replies,case not any good,looking for shop in 50miles of flint,mi
time2roll
I think Jasper does an exchange. Lots of people post good luck with them on transmissions.
BenK
Have seen old cast iron T-Cases crack and have seen some of the NP cases crack, but the difference is that some of the NP cases are made from either aluminum or MAGNESIUM
I'd not fix any and get a uncracked/busted/etc junk yard case and rebuild it
This image is a busted NP T-Case and most likely driven in 4x4 lock on pavement or on good traction surfaces. The below link is to a site that addresses the age old non-4x4 or newbie-4x4 person asking and/or folks providing advice (sure you can) if it is okay to drive on pavement in 4x4 lock...of course a standard 4x4, not all-wheel or full-time...NO IT IS NOT OKAY to drive in 4x4 lock on good traction conditions
Here is why part time 4WD should never be used on dry pavement
This image show why...
dodge guy wrote:
I would go reman or low mile used. I've never seen a T-case blown up!
How did you do it? Curious!
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
path1
I have older Dodge also. Getting hard for some parts on 2nd gens. I've been looking for a fuel tank over 6 months now.
I think you would have better luck on cumnnins forum or moparman. IMO moparman has better info but not as many folks. Ask on both. Good luck. https://mopar1973man.com/
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
troubledwaters
Michigan is a 500 miles from one end to the other. Can you narrow it down a few miles.
1jeep
I have but it was a np231 and the chain failed causing the case to crack, I wouldn't really call it blowing up.
2016 Ford F350 crew cab dually 6.7 platinum with heavy tow and 4:30 gears
2015 Carbon 327 with a BMW k1600 and Canam 1k inside
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
1jeep
"blew transfer case to pieces"
For real if so I would be checking into junk yards for a used one or by a reman if they are available.
just an example
https://shop.advanceautoparts.com/p/retech-universal-remanufactured-transfer-case-umt207-2/10192957-p&c3ch=PLA&c3nid=10192957-P?iv_=__iv_p_1_a_214327102_g_12425515822_w_pla-303447177971_h_9002253_ii__d_c_v__n_g_x_pla_y_6201684_f_online_o_10192957-P_z_US_i_en_j_303447177971_s__vi__&utm_source=ACQ&utm_medium=cpc&utm_campaign=PLA&utm_content=shoppingcampaigns&gclid=Cj0KEQjwrYbIBRCgnY-OluOk89EBEiQAZER58ln9Ikzr5Ulk12hM7b1K4tna67eCFXgXyiVze2L1R8waAkz08P8HAQ
DavidP
Unless you are familiar that a specific shop is very skilled in driveline repair I would install a remanufactured t-case. A good competent mechanic can install one very easily. I would be reluctant to rebuild what you have or let someone talk you into that route as it could prove to be $$$ and less than robust when complete. You can find a reman for around a grand that is completely gone through. Not cheap but you know what youโ€™re getting is solid. There are many good shops you can find online to order from. One of them is Powertrain Products Inc. Good Luck!
Grit_dog
Navigator
Navigator
Not at all. Sorry to hear that. Wish I had a reccomendation for you.
Good luck getting it repaired.
