500 miles under 50 mph
TBammer
Sooo, I posted in an other thread about the new 2500 HD I just bought. Great truck, nice truck, could not ask for a better truck. Buuuut, I'm reading the break in requirements and it says drive 500 miles without towing. No problem, not my first new vehicle and I expected such an instruction.
It's the next part that got me, the manual says to then not exceed 50 mph for the first 500 miles of towing. :E Going to be some slow paced trips. Are they kidding (rhetorical, I know they are not)? That's my rant. Thoughts? Comments?
2016 Chevy 2500 HD, 6.0 gasser, 4.10 dif
2019 Arctic Fox 25W
Reese Pro-Series WD Hitch
43 REPLIES 43
Perrysburg_Dodg
CarnationSailor wrote:
If I'm driving 50 mph in the right lane of an interstate and the average speed of traffic is 70+ mph, everyone approaching me from behind is going to want to pass me.
If I'm driving 50 mph on a two-lane road and the average speed of traffic is 60+ mph, everyone approaching me from behind is going to want to pass me. (Note: Corrected above paragraph since a two-lane road has no right or left lane.)
The percentage of cars that want to pass me is the same - 100 percent in both cases.
However, passing on a two-lane road requires getting in a lane where you could encounter oncoming traffic as well as traffic entering or leaving at intersections. Passing on an interstate is always done with the flow of traffic and there are no intersections.
I don't believe the only factor involved with safety is the speed differential. I think passing against traffic versus passing with traffic has to factor into the equation.
Consider this: California limits vehicles towing trailers to 55 mph including on their interstates. If I'm on I-5 where the speed limit is 70 and people are driving 75+, I am expected to observe the 55 mph limit for trailers.
Did the state of California make an incredibly unsafe decision when they made this law?
If you are driving in the far left lanes on any California highway towing anything you will be ticketed won't you? Trucks or vehicles towing a trailer are limited to the right two lanes right?
2015 Ram 1500 Laramie Crew Cab SWB 4X4 Ecodiesel GDE Tune.
badercubed
If I'm driving 50 mph in the right lane of a two-lane road and the average speed of traffic is 60+ mph, everyone approaching me from behind is going to want to pass me.
I am not going to get into it, but yes, I would argue that California made statistically the wrong choice in having alternate speed limits for those driving on the same road.
https://en.wikipedia.org/wiki/Solomon_curve
2019 Apex Nano 208BHS
2016 F-150 Crew Cab (it's my wife's ride)
Been camping for 37 of my 38 years!
spoon059
SoCalDesertRider wrote:
By '2-lane highway', he's talking about one lane in each direction, not 2 lanes in each direction. There is no right lane on a 2-lane highway, thus, it is far less safe to pass on a 2-lane highway, versus a multi-lane interstate.
You are right, I mis-read it. He wrote 2 lane road, I assumed 2 lane highway. 2 lanes in each direction is a "2 lane highway". Only 1 lane in each direction would be a "1 lane highway" or "2 lane road". My apologies =)!
The rules of the road would dictate that you travel at or near the speed limit on a 2 lane road and pull off to the shoulder to allow traffic to pass if you are traveling below the limit.
2015 Ram CTD
2015 Jayco 29QBS
Perrysburg_Dodg
So when did the gear manufacturers stop heat treating the gears!? I can tell you that this is total BS "The concern is that early on they heat up from the friction as the gears mesh and surfaces harden. If the oil overheats the process is corrupted and can compromise the strength of the parts." If this was true then the gears would become annealed no mater the time. You can anneal steel anytime after it is heat treated. So unless the gear lube is reaching 1400* min (1550-1650) you will never hurt the gears!
Not sure why they are requiring speeds under 50 when towing but it has nothing to do with harming the heat treatment of the gears! My 04 has 210K now and it still has the same rear end as when it left the factory. And no I didn't follow the "no towing before 500 mile rule or under 50 mph" either.
Here is some reading on the Heat treatment of gears if anyone whats to read it.
PA12DRVR
Last new vehicle I bought (circa 2008) had the same instructions. Being a largely by the book guy, how can I tow for 500 miles at 50 mph without being bored?
DW and I took a leisurely weekend trip from Ewe-stun to San Antonio with the commitment to only go on FM roads. Worked out perfectly and, yes, there were several places where could have gone quite a bit over 50, but it wasn't required and made for a scenic and enjoyable trip.
I suspect there are several spots in Michigan where one can take a similar trip.
CRL
My RV is a 1946 PA-12
Back in the GWN
SoCalDesertRid1
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
spoon059
I have no dog in this fight, but do you really want to pick California as the example for an intelligent law design?
All joking aside, 55mph max towing is probably safer, albeit more annoying.
In reference to going slower than the rest of traffic, it really doesn't matter to me which option you chose, so long as you are in the RIGHT lane. 2 lane secondary highway is a fine place to go slower in the right lane. 4 lane interstate is a fine place to go slower in the right lane. One being safer than the other... you could make the argument for or against, but I'm not certain one option is better than the other. Drive safe and at the speed that you feel comfortable with... but like you said, stick to the RIGHT lane if you are going slower than the flow of traffic.
Stay safe everyone!
2015 Ram CTD
2015 Jayco 29QBS
2015 Crossroads Rushmore Springfield
2015 Chevy Silverado 2500HD Duramax
badercubed
I followed the owner's manual and didn't tow above 50 mph for the first 500 miles, but contrary to the advice on this thread, I favored interstates over secondary roads. My thinking was that those wanting to go faster could get around me more easily and much safer on an interstate than on a two-lane road where they would have to hang it out there against oncoming traffic.
What an incredibly unsafe decision.
Studies show that it is not the rate of speed you travel as it relates to the speed limit that is more likely to cause an accident but the rate of speed you travel as it relates to the average speed of the vehicles around you.
tatest
I bought a new car in a town 50 miles away in the 1990s, found a warning like that (not 50 MPH, but don't maintain steady speeds) when I read the manual after getting home. Also learned it wanted 89 octane gas but would degrade max performance to run on 87.
If you can do the 500 before towing, don't sweat the first 500 of towing. Especially if you can do 1000 miles of varied driving before towing. Break-in "restrictions" are actually a lot less strict than they were 50-60 years ago, but we ignored them back then as well. We did usually do the 500-1000 mile break-in oil change (seldom required now and 3000-5000 more likely) before going to the regular (1000 or 2000 mile) schedule.
With modern metallurgy and lubricant technology, the break-in period for some components will be a few hundred to a couple thousand miles, for others (engine particularly) it will be in the tens of thousands. However, today, there are no longer issues with break-in lubricants that allow fast wear then need to be changed, although my Dodge dealer pulled that one on me with a one-time need to change the axle lubricants on a 2004 4x4 vehicle.
And who, besides us OCD engineering types, actually reads owner's manuals? My daughter just bought a car with 137,000 miles on it, I was the one who read the manual. She didn't know she got one with the car, so she didn't know it wanted 89 octane.
Tom Test
Itasca Spirit 29B
Passin_Thru
Drive it like it's paid for.
TBammer
Yeah, thanks far all the offers, but I'll be handling the break in myself. :B
2019 Arctic Fox 25W
SoCalDesertRid1
Dadoffourgirls wrote:
TBammer - I have taken next week off as vacation. I will come get your truck this weekend, finish putting the 500 miles on it, and be willing to tow my trailer up north with your truck and not exceed 500 miles. I will then return the truck for you ready for Labor Day weekend.
Just let me know what time works!
What a great job description! Cruising around in other folks' brand new trucks! :B
98Ranger 96Tacoma
20' BigTex flatbed
SoCalDesertRid1
... because you were too stupid to break it in the way they tell you...
Not a very nice comment.
I'm known be a bit abrasive at times, and very to-the-point. I make no apologies for that.
98Ranger 96Tacoma
20' BigTex flatbed
