6 speed transmission questions.
Bank_of_Dad
So I came out of the ice age and got a Suburban with the new 6 speed transmission (PRNDM_1). Reading the manual, it seems a little daunting.
So how do you use it when towing? And what about steep downhill grades (short or long) when towing. I'm used to just downshifting into 2nd.
Thanks
Judy
57 REPLIES 57
Tystevens
Tystevens wrote:
**I have had major issues hitting "quote" instead of "edit" lately...sorry for the double posts!**
2008 Hornet Hideout 27B
2010 Chevy Suburban 1500 LT, Z71 package, 5.3/6A/3.42
2015 Ford F150 XLT Supercrew, 2.7 Ecoboost/6A/3.55 LS
Prior TVs:
2011 Ford F150 Ecoboost 3.5
2006 Chevy Silverado 2500HD Duramax LBZ
2005 Chevy Suburban 1500 4x4 LT, 5.3/4A/4.10
Tystevens
TomG2 wrote:
What is different about the GM transmission? My 2500HD seems to operate exactly the same way when M5 is selected. I do tap down to M4 if I see a particularly steep hill coming up. When you say you lock it in 5th, do you mean is will "never" downshift? Even with WOT on a 6% grade?
In an auto with true manual control (I don't know if the Ford is this way or not, but my Subaru and Acura have this feature), you can force an up-shift as long as you're going fast enough to allow the transmission to shift into that gear, and the vehicle will hold that gear as long as mechanically possible. So yes, you can stand on the gas pedal and it will not downshift as long as it can keep the speed within the operating range for that gear.
In the GM transmission, if you have it in M5, for example, and step on it, it will shift down to 3rd or 4th gear to get power to respond to your input. It won't make any effort to stay in 5th gear. Just as it would if you had the transmission in "D" and the truck happened to be operating in 5th gear at the time you stepped on it.
Prior TVs:
TomG2
Deleted
Hybridhunter
I had a Chevy 1 ton, and a Ford 1/2 ton. The Ford has true manual control, if you order the tow package, it's my favorite feature when towing. I lock it in 5th on mostly flat terrain, turn on cruise control, no torque converter unlocking, no downshifting. Perfect.
TomG2
Deleted
fickman
Great info. . . saved me from asking the same question as I'm new to towing with the 6-speed.
I'm 99% sure I have the 3.42 gears and I've found I tend to lug in 6th even with a lighter PUP. I do use T/H (although according to a few posts here I don't need to).
I smiled from ear to ear the first time I experienced the transmission assisting me with braking. . . complete unexpected. . . but very appreciated.
DW, DD (2007), DS (2008), DD (2010), DD (2011), and me
2010 Chevrolet Express 3500 LT
6.0 liter V8 SWB 12-passenger van
2008 Fleetwood Utah Popup Camper
Tystevens
Tystevens wrote:
**double post ... sorry**
Prior TVs:
Tystevens
ktosv wrote:
Do you have a 1/2 ton or 3/4 ton? If 3/4 ton, I am thinking you might be able to just drop it into Drive and be good with that size trailer. When approaching a steep downgrade and you think you will need to shift down, just drop it to M. It may automatically drop to the next lower gear than you are in (if cruising in 6th, it might drop to 5th when you go to M). Just shift up and down as needed when needed.
If you have the 1/2 ton with the 3.42, you may have to use M all the time and limit the truck to 5th gear.
Not really. The transmission does a very good job avoiding hunting or other issues. I've been quite impressed with it, even when towing near the max ratings as we do. It also does a good job downshifting to control speed. The only time I have really had to intervene is on steep mountain highways where we need to keep speeds down in the 25-35 mph range for curves and stuff. Overall, I am very happy with the transmission programming. Like others said, mine is just in D, t/h on for 95% of my towing.
Prior TVs:
Tystevens
TomG2 wrote:
Hybridhunter wrote:
....snip...... It only limits up-shifting, ........................snip...........
Funny, mine downshifts with a tap. I often anticipate the extra power needed to climb a hill and tap it down a gear to save the transmission from doing it for me half way up the hill.
Of course it does, if you are in a gear above the gear you tapped down into. If you are in 6th, and you select 5, it will force the downshift. But if you are in 4th and you select 5, it probably will not do anything.
Basically, the same as the old 1-2-3-D setup. If you have it in 3, it will shift thru gears 1, 2 and 3, but will not shift into 4th (or od or D or whatever you want to call it). It is simply less cumbersome to have a button to select range rather than have 6 individual positions for the gear shift lever.
The operation is quite different from an auto with true manual shifting capability, such as my Subuaru or the Acura TL we used to have. In my Subaru, if I select 3, it will will stay in 3 unless I let the speed get to where it cannot physically maintain the gear. I can stand on the gas, and it will not downshift. In my '10 Suburban, if I select 3 and step on the gas, it will downshift to whatever gear it needs to respond to my request.
Prior TVs:
Tystevens
The Texan wrote:
ktosv wrote:
Also, if you select 2, it will start in 2nd gear and stay in 2nd gear. Awesome for a 2wd vehicle like mine in deep sand or snow.
Nope, select 2 and it will start in 1 and shift to 2. It is NOT a manual transmission, just a top gear selector.
You're right, it is just a range limiter, which is a poorly understood feature or function of this transmission.
With the exception of 2, however. From a stop, it will start in 2 if that range is selected. It is to reduce torque and improve traction on slick roads. My '05 4 spd had the same feature. Seems needless since the truck has traction and stability control, too -- it will limit wheel spin on ice in 1st gear -- but that is the feature.
Prior TVs:
wnjj
Nothing funny here; you both agree. If you limit up-shifting to a lower gear, it must downshift. The difference is if you are going slow enough of under heavy throttle and tap it up a gear it won't necessarily upshift.
APT
You are both right!
In normal mode, M2 will start in 2nd gear, skip 1st. In Tow/Haul mode, it will start in 1st gear. M3-M6 will start in 1st gear in normal mode.
2017 Subaru Outback 3.6R
APT
travisd1000 wrote:
GM Says you don't even need T/H until you're > 75% of the tow capacity
While that is true, a high walled RV is more work than any other type of trailer. That's why a TT of 4000 pounds or 10000 pounds uses the same fuel for the same truck.
I tow about 6500 pounds with my 2011 3/4 Ton Burb. I use Tow/Haul mode and M5. I cannot hold 6th gear at 65mph on flat ground, so it takes a little while for the trans to learn (each ignition cycle) not to allow 6th gear.
One difference with using Manual mode (which Hybridhunter perfectly described as a top gear limit) is that you lose most of the engine braking.
Bank of Dad, I hope you enjoy your Suburban as much as we do!
TomG2
Deleted by author
Taco
Manual 5 (keeps it out of 6th) and tow haul when towing. 6th gear is mostly useless when towing if you have 3.73 rear if you are downhill or perfectly flat with no headwind it can hold 6th but mostly it is useless.
I also use an ultra gauge which is an obdII port plug in set of extra gauges. Set it up with the engine load gauge. When you are climbing push the pedal till it says 100% and it will hold that gear giving it full power for that gear. If it loses speed push a little harder and it will downshift but it will tell you just how hard to push to get full power without downshifting.
