Jun-04-2021 05:48 AM
Jun-04-2021 08:01 AM
joerg68 wrote:
Re. Airbags: the airbag compressor is not continous duty. I doubt it will survive running long enough to pull down two batteries.
some more thoughts: I checked the voltage of the batteries and they kept dropping even know the The truck was running so I am bringing it to the shop I think it is the alternator, I am annoyed this happened but it could’ve been worse I could’ve been on the road. Thank you for your responses thank you sir
What voltage does the camper battery show?
There are not many electrical consumers in a truck or camper that can run down two (or possibly even three, with the camper battery) fully charged 70-something Ah batteries in one night. Leaving the truck lights on, or the fridge on 12V, might. A single dome light won't do this.
Do you know if you have a battery separation switch of sorts between truck and camper?
Having the camper on shore power does not necessarily guarantee that the fridge is running on shore power, though it normally should. But it may have been inadvertently set to 12V, or something may have gone wrong.
15 minutes is not long (enough) to charge the batteries. You'd need to know what their voltage was before the jump start.
In any case you need to find out if the problem is with the truck or the camper.
Jun-04-2021 07:55 AM
Jun-04-2021 07:34 AM
Jun-04-2021 07:18 AM
bighatnohorse wrote:these are seal batteries
You need to check the battery fluid with a hydrometer.
A hydrometer is easy to use, inexpensive and available at all or most auto parts stores.
If the battery has a dead cell then it is toast - it won't charge up again. It's toast.
Jun-04-2021 07:08 AM
Jun-04-2021 06:49 AM
Jun-04-2021 06:48 AM
Jun-04-2021 06:44 AM
Jun-04-2021 06:43 AM
joerg68 wrote:. I had to camper plugged in to AC at my house and I just jump started the truck and it started and I shut it down 15 minutes later it won’t start again
I amended my first reply, pse re-read if you haven't yet.
Jun-04-2021 06:38 AM
Jun-04-2021 06:18 AM
Jun-04-2021 06:14 AM
Jun-04-2021 06:13 AM
Jun-04-2021 06:12 AM
Jun-04-2021 06:09 AM
