Jun-04-2021 05:48 AM
Jun-05-2021 12:44 PM
NVR2L82AV8 wrote:. 7.3 driver I will absolutellook into that alternator, I sent the truck to the shop for 2 reasons first is diagnostic the second is the serpentine belt is a major hassle for me and I don’t want to deal with it. Too old anc lazy ,I have not had an issue with the alt in the truck but we are taking a pretty long trip in August so what the hell .As for the batteries I replaced them in February so they are new I hope not shot. Thanks
Yep, it's your truck. As a 6.0 Ford PowerStroke owner I'll add some things to ponder (not from experience--sarcasm). If you rely on your Trucks alternator to "charge" your Camper batteries you should definitely think about a bigger alternator than stock or OEM. I replaced my OEM alternator five years ago and all my truck electrical issues vanished -- full stop. Since I had plenty of "amperage" available I even added a 6AWG line to charge my batteries separately---I could have never done that with an OEM Alternator. My Leece Neville 230 AMP alternator will charge at idle--you're OEM will struggle if not provide zero charging capability.
Go on-line and invest in a 230AMP alternator - Trust me, You will kick yourself for not doing it a long time ago.
I'd also offer that you need to replace your truck batteries as a pair. Since they are below 12.6V I'd charge them up. I've bought new batteries before and had one go bad - not uncommon. Take your new batteries back to the place you bought them and have them do a "Load" test. You'll know immediately if you have a bad battery and they should replace it for free if you are still in the warranty period. Another word of caution. Just because your Truck battery gets a jump to start does not mean it'll charge. An alternator requires V to excite the alternator. Generators do not. Lots of folks learn this the hard way.
If you can afford it get AGMs for the diesel. Here's a link to a 230AMP. You can search on-line for the best prices. Be advised Leece Neville's are produced in the US. So, there are Chineeesm Knockoffs (go figure). Buy from a reputable dealer.
Jun-05-2021 10:45 AM
Jun-05-2021 04:10 AM
7.3driver wrote:yes it did rain that night. but they were new, good as opposed to new (bad) time will tell. Good to know!
This may sound like a silly question but did it rain over night when you came outside and found the truck batteries dead ?
The reason I ask is cause I have a early 1999 F350. Sometimes after a good rain what happens is water will get to the inside of the outer door handle where the electrical switch is for the inside illumination lites and cause them to come on and run the batteries down.
Ford may have corrected this on later models.
Jun-04-2021 10:23 PM
mattyj wrote:
Thanks everyone I jumped the truck and the voltage did not increase at first I thought it had something to do with the tc but I think that the tc was on truck and this happened was just a Coincidence. So when I had the truck running last night quite a while I might have killed the batteries due to the alternator being no good. I am waiting for AAA to pick up my truck and bring it to the shop, no trip this weekend, I really lucked out this happened in my drivewayAnd not on interstate 81
Jun-04-2021 09:25 PM
Jun-04-2021 09:09 PM
Jun-04-2021 10:04 AM
Jun-04-2021 09:49 AM
Jun-04-2021 09:31 AM
Jun-04-2021 09:12 AM
Chuck and Di wrote:
If I read this correctly the truck batteries are 11.38 and camper batteries are 12.56. This means the camper has nothing to do with it. Problem is contained to the truck.
Jun-04-2021 09:06 AM
Jun-04-2021 08:38 AM
Jun-04-2021 08:10 AM
Jun-04-2021 08:03 AM
