Adding a Refrigerator
aquavita
We just purchased a new TT that does not have an outside kitchen. For the most part we do not want one because it takes up a lot of our outside storage. However, I would like to add a small drink fridge to the storage area that would have been the outside kitchen if we had one.
Does anyone know where I could buy such a fridge? If I buy just a small cheapo fridge not meant for a TT is that going to cause a problem? I don't want to spend a ton, but I would like to be able to store drinks and small snacks outside so my kids are not constantly running in and out. Plus cut down on the ice we purchase.
8 REPLIES 8
chr_
Nothing keeps the beer colder than a good cooler and ice...
-CHR$
1996 Safari Sahara Edition 35' Diesel Pusher. Just getting the Solar stuff started.
thomasmnile
We have a 1.6 cu ft. Danby fridge (110v) in the basement of our Jayco Whitehawk(installed option by Jayco). Have used it once and was underwhelmed. Temperature control set to near max. cold and it produced barely cool beer and soda after hours of operation. As nice an idea as it may be, I think the problem with the basement fridge may be the manufacturers (at least this Jayco model) make no provision for heat dissipation from the refrigerator's operation. The refrigerator evaporator coil is trying to dissipate heat from normal operation into a closed space, made even hotter with the sun beating down on the TT all day.
ScottG
kevden wrote:
Our TT has an outside kitchen. I installed an inverter to power the fridge while traveling. The Trucks alternator keeps the battery charged while driving, so no worry about the inverter draining the TT battery. I put in a 1750 watt inverter, but I have read that an 800 watt unit will work. The fridge uses much less than that while running, but needs a higher wattage to start the compressor.
I've been considering the same floor plan. I also considered adding the inverter to keep that little fridge going but I was concerned there isn't enough air space for the fridge to run and cool while the outside door is closed.
I take it you've had no problem with it?
Thanks,
Scott
kevden
2012 Keystone Outback 312bh
2003 GMC Yukon XL 2500 4X4 Quadrasteer
2010 VW Routan
2007 Chrysler Pacifica AWD
skipnchar
Only problem with using a dorm fridge is you're limited to using it where you have electric hook ups. If that's where you stay it is a viable solution.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
APT
$50-300. Best Buy, Walmart, etc.
2017 Subaru Outback 3.6R
Dog_Folks
A dorm fridge will work just fine for the needs you have outlined.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
GaryWT
We have the outside kitchen and still can sleep 4 in the bunkhouse. If you have a spot for a fridge, pick up a dorm type fridge at wally world or where ever and find a place to plug it in.
ME '63, DW 64, (DS 89 tents on his own, DD 92 not so much), DS 95
2013 Premier Bullet 31 BHPR 2014 F350 Crew Cab 6.2L 3.73
