Feb-09-2023 05:50 PM
Feb-22-2023 05:28 AM
Feb-11-2023 04:45 PM
ken56 wrote:
Wait, let me throw my wrench into the works here. A 50 amp unit consists of 2 legs of 110 volts coming into the unit. The distribution panel is like one in your home. Every other finger on the bus bar is taken off one side or the other so hooking up any 2 pole breaker will be staggered.....right?
Feb-11-2023 01:06 PM
Bud
USAF Retired
Pace Arrow
Feb-11-2023 01:01 PM
Feb-11-2023 06:41 AM
Feb-11-2023 04:30 AM
Feb-10-2023 03:36 PM
ScottG wrote:BB_TX wrote:thegabrielles wrote:
I will check the power on the RV, just and assumption but wouldn't the manufacturer spread the current out evenly on a camper that is prewired for 50amp service... I know what assume means. 🙂
You would like to think that wouldn’t you? I think most are on separate hots but you would not be the first to report them both on the same hot.
Interesting discussion. I still don't see why there is any need to balance. A 50A leg can easily handle 2 AC's even if something like a water heater is running. All three of those running at the same time would still be less than 5000 running watts - well below the 6000 avail. The RV's panel doesn't care - you could max out one leg and have nothing on the other leg without any heat, etc.
Feb-10-2023 01:54 PM
How about those large class A's out there with 3 and even 4 AC's purring along in Las Vegas? Do they never run three or 4 at once? It sure sounds like they do when you walk past them..
If I'm missing something, I'd enjoy learning.
EDIT: found this old thread that suggests running three at once (so 2 on one leg) is no problem: Linkaroonie
Feb-10-2023 01:02 PM
Feb-10-2023 12:37 PM
Feb-10-2023 07:45 AM
Bud
USAF Retired
Pace Arrow
Feb-10-2023 06:56 AM
Feb-10-2023 06:44 AM
Snip...
The RV came prewired for 50Amp so adding a second AC shouldn't be too complicated... except finding one. The specs on the ceiling where the wiring is state: 110-125Volt, 60Hz, and here is my problem 16Amps Maximum. I am struggling to find an AC that will meet the 16Amp minimum (especially on start-up).
I am looking to add heat to that AC as well. I would appreciate any advice or point me in the right direction.
2022 F150 Powerboost Platinum (purchased Nov 2022, ordered May 2022)
2022 Cruiser Aire 28RKS Purchased Aug 2022
Feb-10-2023 06:16 AM
