โJan-20-2017 08:52 PM
โJan-21-2017 08:26 AM
โJan-21-2017 08:17 AM
thedavidzoo wrote:
Check out AMSolar's video on sticking panels to a roof with VHB tape:
https://www.youtube.com/watch?v=mXiNLCWPPkA
โJan-21-2017 08:13 AM
work2much wrote:
I screwed mine in with ample dicor covering the screw heads but I believe that if you used a combo of adhesive and covered them with a good swath of eternabond tape over the feet and down to a clean roof that they would stay in place. Any one that has tried to remove eternabond tape knows that stuff is tenacious to say the least.
work2much wrote:
...I believe that if you used a combo of adhesive and covered them with a good swath of eternabond tape over the feet and down to a clean roof that they would stay in place. Any one that has tried to remove eternabond tape knows that stuff is tenacious to say the least.
โJan-21-2017 07:37 AM
โJan-21-2017 06:31 AM
โJan-21-2017 05:27 AM
SCVJeff wrote:
The AM Solar mounts are VHB and they are meant to attach to a SOLID roof, not rubber. It matters just as much what adhesive was used on the rubber membrane itself. If you don't screw those mounts into the roof you'll find the panels and likely a large piece of roof itself on the side of the road
โJan-21-2017 05:15 AM
โJan-21-2017 03:53 AM
โJan-21-2017 02:54 AM
