agm battery
plock40
hi everyone, I am looking to install two agm batteries in our artic fox 990, but the batteries are to tall, will I have to remove the tray or just stay with wet batteries.
3500 Ram 4x4 Dually Crew Cab Longbed
990 Artic Fox Camper
2005 Cardinal 5th Wheel
11 REPLIES 11
billtex
ADA6969 wrote:
Just installed 2 AGM's took tray out put thin carpet on bottom works great.
Be sure your charger/converter is sufficient for properly charging AGM's.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
ADA6969
2012 RAM 3500DRW MAX TOW 4WD AUTO STD CAB ST DIESEL STABLE LOADS AIR BAGS AND RS9000XLS, ROADMASTER 1 3/8" REAR SWAY BAR 2021 AF 1150 DRY BATH TOWING 2017 JEEP RUBICON JKU BUILT. OR 2020 JEEP RUBICON JL BUILT
plock40
thank you for all your input
bobndot
just search what you want and size it .
Lifeline grp 27 HT 8.9"
Trojan grp 31 HT 8.1"
JohnAM
jmckelvy wrote:
What size are you looking at using? I have two 12 V Lifeline Grp 27s. They fit using the tray.
Same for me.
2011 RAM 3500 CTD Laramie DRW 4x4, Torklift, Superhitch, Stableloads
06 Dodge 3500 CTD Quad DRW 4x4 6sp Man, TorkLift, Superhitch, Stableloads, KYB Monomax (Traded in)
11 Lance 1191
97 Lance 980 (Sold)
billtex
Batteries are standardized...should not matter what type.
Did you replace with same size?
2020 F350 CC LB
Eagle Cap 850
JimK-NY
I pulled the battery tray out of my Northstar Igloo and was able to barely fit 2 Lifeline 30 HT AGM batteries with 150 A/H each. The 300 A/H total is a substantial improvement over what I could accommodate with the tray. Of course with AGM batteries the tray is not needed because there is no maintenance or testing needed.
deltabravo
I pulled the tray out of my AF811 when I upgraded to AGMs back in February.
I honestly kind of disliked that tray anyway.
In place of the tray, I put in a 3/8" piece of plywood and slipped some thin strips of oak in between the batteries to act as spacers to keep them apart, and to keep them from moving in the compartment.
I have pics of it, but I don't think I every uploaded them to my photo sharing account.
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
jmckelvy
06 RAM 3500,Dually,CTD,Auto(ATS Stage 1),QC,4X4,PacBrake,Spyntec Freespin Hubs,60 Gal Titan Tank,EFI Live, Line-X,Torklifts and SuperHitch,Fastguns
2013 Arctic Fox 990, 275 Watts Solar, 2 Grp 31 AGMs
US Navy 1964-1968, 2-Tour Vietnam Vet
Reddog1
I have a single 100 AH AGM since 2005. It is mounted inside of my TC. I could go with more AGMs, but really do not have the need. I would go to a lot of work to prevent going back to flooded wet cells.
This is my preference, note the battery dimensions at the bottom of the page.
http://www.bestconverter.com/UB121000-100-AH-Deep-Cycle-_p_293.html#.VVVX0vlViko
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Buzzcut1
Nomad II
Nomad II
remember AGM batteries can be laid on their sides with no adverse effects. Also the Interstate versions are shorter and narrower than some of the others
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
