Air Shocks
Montana_Mike
What about air shocks on a towing rig. Anyone use these instead of air bags? Or is that to much pressure on the shock mounts?
Time to get camping! 2013 28'Shadow Cruiser
One wife, 4 boys, 2 dogs and a cat.
Montana Mike
25 REPLIES 25
Ron_Gratz
Lynnmor wrote:
If you have soft rear springs then even a correctly adjusted WDH will not raise the truck to where it should be.
Are you saying the rear end should be raised to the unhitched height? If so, why?
Ron
APT
I towed my TT with a previous F-150 that was 0-500 pounds over GVWR depending on the trip. If you return the front axle to unhitched weight, the rear will settle about 1.5-2" lower than unhitched height. Any more than that, and you exceed GVWR and probably rear axle rating. There is a reason why the rear springs are soft, the vehicle isn't designed to handle more weight!
2017 Subaru Outback 3.6R
Lynnmor
APT wrote:
What is your tow vehicle and are you using a weight distributing hitch? IMO, there is no need for adding rear suspension support with a properly adjusted WDH. Using additional rear suspension support tends to mask overloaded situations and makes WDH adjustment more complicated.
APT
Hondavalk
Montana Mike wrote:
Ok I'll do air bags. Thanks
Firestones worked great for me.
Montana_Mike
Montana Mike
Hondavalk
Montana Mike wrote:
So what happens with vehicle's with self leveling shocks/ suspension.
Would like to raise about 2 inches or less for headlamps.
The air BAGS inflate
Montana_Mike
Montana Mike
Hondavalk
beemerphile1 wrote:
Shock mounts are not meant to carry weight.
X2
beemerphile1
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Mark_and_Linda
I installed a set of Timbren Support Enhancement blocks on mine. It rides a little rough without the trailer but it is okay for me.
Mark
