Airbags- built in air compressor or manual fill?
cartmancartman
Which is the best to go for a truck camper, built in air compressor or manual? It is roughly a $800 price difference between the two (including labor), I dont mind spending the money if it is put to good use. How often do you adjust the air bag settings?
I like to keep it simple as one of the parts or if the compressor goes out.
25 REPLIES 25
Reddog1
I have had no on-board compressor, and have/had an on-board compressor. I recently changed Trucks, and moved my on-board compressor and added air bags.
On my current truck, I use my airbags to to level side to side when camping with my TC. It is very convenient having the on-board compressor. I do not need the airbags for my 4200 lb TC, due to the existing suspension. NOTE, DO NOT NEED. That said, should I tow a heavy trailer, it could be to my advantage having the air bags. There are circumstances that an on-board compressor is nice, if you want to spend the money.
I also have a 5th wheel. I have had occasions where I did not want to disconnect from the 5th wheel, but needed to raise the front of the 5th wheel. Rather than use blocks and other stuff, it was very convenient to simply raise the 5th wheel plate in the truck with the air bags.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
dave17352
Seems a little over zealous. But oh well. You just deleted the original posters second question and my response. I don't understand that at all. Have a good evening.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
Tom_Anderson
BTW, I bought the single compressor and installed it myself, so my cost was closer to $300. I didn't need the ability to adjust leveling side-to-side, or wireless remote control, or any of that fancy stuff. If it were going to cost me $800, I'm not sure I would spend the money.
dave17352
Wow Reddog1 you notice his last question the OP posted himself.
Reddog1
It can be argued forever if you should or should not use air bags. Your question was "Which is the best to go for a truck camper, built in air compressor or manual?". Post that do not address your question (Which is the best to go for a truck camper, built in air compressor or manual?) will be deleted as Off Topic. For members that want to argue Pros and Cons of airbags, I suggest you start another thread and not hijack this one.
Wayne
Moderator
Toad: 91 Zuke
Buzzcut1
Nomad II
Nomad II
I use a bike pump. I use three pressures. one for no trailer (zero psi) one horse in the trailer (25psi), two horses in the trailer (35 psi). It takes about three pumps per bag. That to me is not worth spending 800 for a compressor system
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Tom_Anderson
I only carry my camper occasionally, and sometimes tow a trailer behind it. So my airbags aren't always at the same pressure. I used to fill them with the external valves and my garage air compressor, until I got the onboard compressor. The convenience of the onboard compressor is well worth the cost, IMO.
cartmancartman
Came across this on youtube:
https://www.youtube.com/watch?v=ydQMZ_fAUH0
dave17352
I love gadgets. If you have plenty of money and like gadgets get one for sure. But for air bags you don't need it. Might come in handy for airing up a tire. When I use to have them I would put on the TC and pump them up to where I wanted them and that was it. They are good for leveling the load. There certainly are other options. I have used timbrens and now lower stableloads from Torklyft. I like both of these products. Cheap and work well.
jimh406
I rarely change my pressure. I'd say never, but I guess I've changed it before. They hold a tiny bit of air, so any pump works.
Colo_Native
I just use a $10 bike pump, you buy a lot of them for the price of a compressor
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
