โAug-28-2017 04:26 AM
โAug-28-2017 09:14 PM
valhalla360 wrote:
A little correction: Most new RV's regardless of siding use Aluminum studs not wood, so having aluminum siding does not mean you will have wood studs that will rot.
Of course, water inside the walls is a bad thing no matter what construction method is used.
โAug-28-2017 07:26 PM
goducks10 wrote:
Aluminum dents real easy, fiberglass sided don't.
Both can leak. One will rot (wood w/aluminum siding) the other will delaminate (fiberglass over aluminum frame).
Fiberglass sided can have higher R value for insulation.
โAug-28-2017 06:08 PM
wing_zealot wrote:SidecarFlip wrote:Instead of waiting for your rebuttal, why don't you try Google. Maybe you'd come away with newfound knowledge. I've had my filon sided trailer repaired and I'd bet you couldn't find where.troubledwaters wrote:SidecarFlip wrote:You don't know what your talking about.
It's not fiberglass per 'se, it's Filon which is a vacuum bonded fiberglass hybrid. It's very difficult to repair if damaged, really the only repair is panel replacement....
Still waiting for your rebuttal...:S
โAug-28-2017 05:40 PM
โAug-28-2017 04:59 PM
โAug-28-2017 03:07 PM
โAug-28-2017 01:24 PM
โAug-28-2017 01:12 PM
โAug-28-2017 10:52 AM
โAug-28-2017 10:46 AM
Bumpyroad wrote:Acdii wrote:rbpru wrote:
In my humble opinion, the floor plan and interior components far outweigh the exterior covering.
Good luck
This is the most honest answer here. Both have their advantages and disadvantages, but what it really comes down to, what do you like? You can have a fancy slab side with a useless floor plan, or you could have an ugly rib side with a really nice floor plan, or visaversa.
Way I see it, I don't care what it looks like outside as long as it is comfortable and functional inside.
the construction of the RV is my first "cut". no rubber roof, TPO remotely possible. I want fiberglass sides and roof. then I look for one the size/price/and layout I prefer. I will NOT sacrifice construction for floor plan.
bumpy
โAug-28-2017 10:18 AM
Good luck
โAug-28-2017 10:13 AM
โAug-28-2017 10:04 AM
โAug-28-2017 09:36 AM
โAug-28-2017 09:22 AM
