โDec-01-2020 10:35 AM
โDec-05-2020 07:52 AM
โDec-04-2020 09:31 AM
โDec-03-2020 01:48 PM
JRscooby wrote:Gdetrailer wrote:JRscooby wrote:
Why use metal to replace the tin box the factory calls "bumper"? PCV to hold drain tube be about same protection, won't rust, and let stinky slinky last longer.
Sure, you could just remove the old damaged metal bumper and wire tie on the famous PVC sticky slinky tube and not bother with any metal..
However, in the case of an rear end accident you most likely would be wishing that you HAD that metal tube there instead of PVC plastic.
Even though that metal bumper tube is pretty flimsy, it IS there as a safety item for the DRIVER behind you.. Protects the driver behind you from getting speared by your trailer frame!
Does also provide some protection to your trailer in case of minor bumps like backing into something you can't see (power pole, short pipes or other objects).. PVC plastic is just going to shatter and crumble and fall away.
Well looks like a major part of the idea was missed;JRscooby wrote:APT wrote:
I highly recommend installing a 2" receiver such as this Curt model vs. using the bumper for, well, anything.
Likely a good idea. IMHO, better would be build a bike rack that bolted or welded to frame. Save the pin on rack for TV when not pulling trailer.
The hitch, or a bike rack built and mounted to the frame rails would work better than the tin box to keep a car out of trailer.
And for the low speed impact, bet take less force to fold stock bumper into house than PCV. And what will dent the stock may not faze the PCV
โDec-03-2020 12:35 PM
โDec-03-2020 12:21 PM
โDec-03-2020 11:40 AM
โDec-03-2020 07:50 AM
colliehauler wrote:JRscooby wrote:I would agree with this as well. Along with building a heavier bumper to replace your paper thin bumper.APT wrote:
โDec-03-2020 05:55 AM
โDec-02-2020 08:34 PM
time2roll wrote:
If you want to hang stuff off the back do not use the bumper. Get a properly installed class 3 hitch.
โDec-02-2020 05:23 AM
โDec-02-2020 04:41 AM
โDec-02-2020 02:31 AM
โDec-01-2020 10:01 PM
โDec-01-2020 01:45 PM
