Anyone install front hitch on new trucks?
FireGuard
I've been considering ways to take my dual sport on my truck.
I could probably upgrade to the Reese Titan or Superhitch, but the front may work.
Looking under my 15 Ram, I don't see the big solid "beams" the older trucks had.
A lot of stuff under there like radiators, coolers, etc.
Is there a stabdard hitch made for these trucks or is it a custom job?
I'm sure if there's a will there's a way.
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
15 REPLIES 15
Nautique200
I've had the Curt on my truck for two years. No issues, works perfect. I currently use it for a Kuat 4 bike rack and I will be adding two place motorcycle rack soon. I will be hauling my KTM 500 XCW and my sons 50.
If you want a picture or two let me know and I can email it to you.
2016 Ford F450
2015 Arctic Fox 1150
2009 Trails West Warm Blood Trailer
trailgranny50
Not new truck but new bumper with built in receiver and brush guard. Haul spare tire up there and adding actual grey tank in spare's vacated space.
2004 Chevy 3500 Duramax all stock
1990 950 Shadow Cruiser Hard side multiple add-ons
Ancient Valco 10'x5' John boat
2011 Toyota FJ Cruiser Trail Team
One-eyed Trail Horse and one horse trailer
Rocky, Annie, Muffie traveling Fur Babies
StrumminBass
I'm about to put on a Curt (curtmfg.com) front receiver on my 2016 3500 as the height is lower. I'm adding a Snowsport plow and will also use it for my bike rack. The plow required a working height on the receiver between 8-16".above grade.
Randy
2012 Northern Lite 811QSE
2016 RAM 3500, 6.4L Hemi, SRW, CC, Short Bed
Christl
I had a front hitch installed (bolt-on) on my GMC 1500 and added a front aluminum storage rack from Princess Auto. With a Roadmaster sway clamp added to the receiver hitch shaft, it worked wonderful on 12000km trip on very rough roads in Labrador. I intend to add a similar front hitch and rack to my new GMC 3500.
davidaf
I had one welded to the front. The bolt in options would sit too low. Didn't cost much more to make it permanent.
2016 - Heartland Landmark Newport
2006 - Lance 1181
2005 - Fleetwood Prowler AX6 365BSQS - San Felipe Mexico Getaway!
2016 - Ram 3500 DRW
owenssailor
I have a Curt on the front of my Chev. It bolted on no problem and works well
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
FireGuard
Thanks for the responses, all good points to consider.
13Jeep Wrangler
07 Ragen 21FB
14 Suzuki DR 650
deltabravo
How to carry a motorcycle
deltabravo
Add a Versahaul bike carrier to a hitch. Dual Sport bike on a front hitch would block too much of my view.
Super_Dave
FireGuard wrote:
I like the Draw Tite as it bolts to the existing tow hooks.
It has a 500 lb vertical weight, I wonder if a motorcycle on a rack weighing close to that bouncing up and down will cause a problem over the long run?
Maybe some turnbuckle supports could be added? Even with bikes, I find enough slop in the hitch to require some tying off.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
egarant
I have a RAM similar to yours, I installed the Draw-Tite that bolts on to where your tow hooks on.
The one caution I will point out to you is that on the RAM truck that hitch mount will be much higher up in the front of the truck, almost in the middle of the front end. Most other mounts attach quite a bit lower to the front of the truck.
So when I mounted my bike rack, there was no adaptor listed or tried that could lower the bikes enough for me to see over them, they stuck up over the hood by a good 2 feet. You would have the same problem with your motorcycle.
2021 FORD F350 dually 4x4 with 4.30 gears, 013 Eagle Cap 950, 480 Watts Solar, 3K Victron Multiplus II, Victron smart DC-DC charger, Victron 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
FireGuard
13Jeep Wrangler
07 Ragen 21FB
14 Suzuki DR 650
FireGuard
Thanks, guess I should have googled it first. 😞
It just didn't look "hitch friendly" under there.
13Jeep Wrangler
07 Ragen 21FB
14 Suzuki DR 650
Reddog1
Quite a few here.
Wayne
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
