Arctic Fox Says no off road????
ADA6969
So I just got rid of my 02 990 A/F dry bath. Ordered a 2021 1150 dry bath. Called Arctic Fox to ask if the new camper will hold up to off road as well as the old A/F. We are talking 2wd roads small rocks, graded etc. His quote. I don't recommend you off road with any of our campers. Any input?
Thanks, Andy
2012 RAM 3500DRW MAX TOW 4WD AUTO STD CAB ST DIESEL STABLE LOADS AIR BAGS AND RS9000XLS, ROADMASTER 1 3/8" REAR SWAY BAR 2021 AF 1150 DRY BATH TOWING 2017 JEEP RUBICON JKU BUILT. OR 2020 JEEP RUBICON JL BUILT
29 REPLIES 29
brholt
Off road report with an AF1150
AF1150 off-road
NRALIFR
It’s been my experience that the bigger/taller/heavier the camper is, the driver will say “I give up” off road sooner than the camper will.
2001 Lance 1121 on a 2016 F450 ‘Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam types………..Let’s Go Brandon!!!
rexlion
I can imagine some of the complaints the mfr is worried about.
"You said it would be okay off-road! Your lousy product popped a seam on the Rubicon Trail, so you should pay for the repairs!" 😉
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
Bert_the_Welder
Can;t blame them for covering there butts. You say 2wd gravel. He's thinking "off-road" off-road. How many companies hear "But it was just a maintained gravel road" when they know there's no way Joe Dirt had the damage he's got from anything less then Jeep trails. First guys was reasonable in his reply given today's scale of honesty. And I'm not saying that's you. But they have to cover themselves for the lowest life form and the way they drive as well. Results are gonna vary on an average pot-holed fire road depending if you're doing 20km/h or 80km/h. 😉
:h 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
mkirsch
Nomad II
Nomad II
ADA6969 wrote:
Just be smart about it.
Not for nothing but you should have realized this was the answer from the get-go.
First guy probably imagined rock crawling when you said off-road.
Technically, driving through the RV park to your campsite is off-road.
jimh406
ADA6969 wrote:
I just talked to Doug at Northwood He said no problem going off road Just be smart about it. Well I am happy again
That's good.
ADA6969
Reno/ Sparks paved roads as bad as some of my off roads
gbopp
You won't be able to take it on any roads in Pennsylvania. :B
Lwiddis
Doug is CYAing by saying “just be smart about it.”
jaycocreek
One must define off roading..There is off the pavement on gravel and dirt roads,then there is off roading which is off any maintained road which the majority ot truck campers here can't do anyway because there to heavy/to wide/to tall and to long..
I traded in my short Class C with great ground clearance, because every trip seemed to pop a seam, being built off the frame..I am not having that issue with my TC in the bed of the pickup and it only flexes with the pickup bed.
Something like the Mcgruder road, from Elk City Idaho to Darby Montana through the mountains on a primitive un-maintained road, might define off roading..It is a road but a terrible road..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
ADA6969
BurbMan
TxGearhead wrote:
eh, just lawyer talk, CYA.
Now if you have structural issues...offroad? No not me.
^^^This^^^
TxGearhead
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
ADA6969
I thought that is one reason we have truck campers. To go were you cant get a larger RV. My sales info for 2002 A/F says how better built they are for off road use compared to other brands.
jimh406
I don’t think that is surprising. Probably almost no RVs are recommended to go offroad. That being said, there are plenty of paved roads that are pretty rough and some gravel roads are pretty rough as well..
