Are all TC roofs this thin?
anutami
I knew it was thin, but Very alarming when you see for yourself how thin the roof actually is. Northwood doesn't show 150 people on top of a wolf creek. I guess it holds my weight okay. I was wondering if adventurer, northstar and Lance, etc have similar designs.
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
16 REPLIES 16
SidecarFlip
DWeikert wrote:
SidecarFlip wrote:
The roofing (shingles) on your house aren't very thick either... What is your point?
Your shingles generally also have a layer of roofing felt underneath and both nailed to roofing grade plywood/chip board for support.
So does your TC roof. No roofing felt but 'luan' or plywood under. I liked my old Lance with the one piece aluminum sheet roof.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
SidecarFlip
trail-explorer wrote:
Gary3 wrote:
Most campers are 2in thick on the roof and sidewalls
None I've ever seen have 2" thick sidewalls. That's excessively thick for a sidewall.
News to me. Maybe 1" thick.
DWeikert
Dan
2008 Chevy D/A 2500HD ECSB
2010 Northstar 8.5 Adventurer
DWeikert
1/2" marine plywood under a single sheet of TPO.
Dan
SidecarFlip
trail-explorer
Bob
Jfet
Our roof is 1/2" marine plywood (7 ply) with 0.040 aluminum sheet over that and 1/8" of truck bed liner over that.
Still pretty thin when you think about it though?
jimh406
I think my roof is thicker, but I haven't measured it.
Rickj91
I tore the rubber roof on my 2013 Wolf Creek and the insurance company covered the repair. My RV guy added 3/8" plywood over the original plywood, so it is now very solid, although I had been on it before and never noticed any give to it. Very happy with our Wolf Creek.
2005 Chev 2500HD D/A,EC,SB,32 in. Hitch Ex. 2013 Wolf Creek 850 SB, 2007 Mirage 6X12 Cargo Trlr
Gary3
Most campers are 2in thick on the roof and sidewalls Lance has always had thinner walls and roofs.I think when they had the metal roof it was 2in thick but there sidewalls were thinner than they are today. Its still considered a 2000ib roof must be in the design because I walk all over mine and there is no give.
Gary  Lance  1191 solar Gen.
Fastbrit
1/4 plywood 4" of styrofome in my chalet.
Ducted a/c in roof
1997 Dodge Ram 3500 CTD. Timbrens all around, Bilstein shocks.
2014 Chalet TS116
joeshmoe
And theres your price difference between a wc and af. Ours are definetly not a true 4 season camper
My wife says the whole ceiling bows quite a bit when I'm up there. Granted, I weigh 250. I try to limit my time on the roof, So I send my wife. Lol
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
mellow
Yea, that is about right. Crazy isn't it? And to think I have never heard of anyone falling through the roof doing normal repairs and cleaning, unless it was rotten.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
Boatycall
Just to get a little more headroom in my shower, I removed the inner sunlight plexi dome. I can say on my Eagle Cap it is much thicker. Now, I'm not implying mine is great, but...
Mine is a sandwich of 1/4" plywood, then 1 1/2" foam, then another sheet of 1/4" plywood.
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
