โOct-10-2015 03:41 PM
โOct-24-2015 10:59 AM
Mikesr wrote:hohenwald48 wrote:
Funny how everyone worries about "flushing the crud" out of the RV HWH. When was the last time you flushed your HWH at home? I bet for most folks the answer is never.
I agree 100 percent but being that the RV HWH is only 6 gallons and is used in various areas with hard water or high calcium it's probably a good idea to flush them.
The Suburban used an anode rod and the rod is designed to break down the minerals in the water and it does leave behind sediment.
Maybe some with more Atwood experience then me can weigh in on sediment in an Atwood.
I know my other TT with the Suburban had a lot of sediment each year.
On a side note I think most home HWH's have inlet tubes that create a swirl within the tank to prevent sediment.
โOct-24-2015 10:06 AM
โOct-24-2015 10:04 AM
facory wrote:
GrandpaKip where di you buy the drain valve?
โOct-24-2015 06:58 AM
samhain7 wrote:I put mine back in place but very loose.
Does anyone leave the plug out over the winter?
I secure it back into place. That hole looks like plenty of room for a mouse. Which would totally be my luck.
โOct-24-2015 06:14 AM
โOct-15-2015 04:51 PM
โOct-15-2015 04:01 PM
โOct-15-2015 09:04 AM
โOct-15-2015 03:57 AM
โOct-11-2015 10:49 AM
Mikesr wrote:enblethen wrote:
I just went out and verified. It is 15/16 inch.
Thanks I will take both sockets along.
โOct-11-2015 09:38 AM
Old-Biscuit wrote:LinkedXJ wrote:GrandpaKip wrote:
Mine was 7/8. I replaced it with a butterfly valve that makes it much easier to drain.
Bingo!
Do this!
Butterfly drain / Petcock
Do you remove valve and flush crud out of tank?
โOct-11-2015 08:28 AM
โOct-11-2015 08:12 AM
Bud
USAF Retired
Pace Arrow
โOct-11-2015 07:32 AM
Mikesr wrote:
Thanks for all the good responses to my question. Looks like it will be 7/8 6 point.
