Aux diesel tank in bed question...
Our_Place
I purchased a 2008 Silverado and it already had a 74 gallon aux tank in the bed hooked up to the fill pipe of the main tank. I sold the 74 gallon tank and purchased a smaller 37 gallon but was told not to hook it to the main tank, but not given a reason why? The previous owner had the valve open all the time and told me not to remove the main tank fill cap but just to fill the bed tank because they are connected, is that ok??
2008 Silverado 3500HD crew cab 4x4 SRW Duramax Allison 6 speed
2014 Cougar 327 RES "Campy"
22 REPLIES 22
hawkeye-08
Regarding the pump attendant removing the fuel cap when you don't want it touched, just switch to locking cap and don't give them that key.
Bird_Freak
GoPackGo wrote:
I have an RDS tank. The RDS install kit INCLUDES a shut-off valve where it plumbs into the main (OEM) fuel filler line. When the fuel level backs up the OEM filler line and reaches the valve, it closes, stopping more fuel from flowing. This way it cannot get up to the level of the outside filler cap.
Northern Tools has the kit. $80.
Tim
I just installed one of these in my buddys new truck last weekend. Works really well.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
hitchup
We've had the DIY RDS gravity fed in-bed tank. It did leak after awhile if DH left the valve open. But the Ford dealer fixed it for us.
Then we upgraded to the in-bed Transfer Flow fuel pump version with a professional installation. DH switched his tonneau covers a few times until he could find the right one to fit over the tank.
Finally, we upgraded the truck and had Ford install the under-bed Titan replacement tank. It's been the best and easier. Just one fill-up, instead of two.
Still feel Ford needs to go back to dual tank option. Then you can fill on either side of Truck.
2014 DRV Mobile Suite Estates 38RSB3....our custom home
2014 Ford F450 KR CC 4x4......his office
2015 Lance 1172 TC.....mobile Motel FOR SALE
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
wlstroud
My RDS aux tank has a tank shut off and a float check valve in the tee on the filler pipe. The check keeps filler pipe from filling up to the truck fuel cap. The only problem I've had in 8 years of aux tank use is I can't leave the tank "on" all the time as that throws an engine code when the computer doesn't see the main tank fuel level decreasing while driving. I have a 99 gal tank/toolbox. It's been great for range increase and for fuel price shopping.
Larry (WB4WSA) and Sheila
2006 Ford F350, CC, XLT Dually 6.0 PSD
2006 Keystone Copper Canyon 339FWTSLS FW
2017 Flagstaff Microlite 25KS TT
wlstroud
Our_Place
Ok let me clear some things up, first I don't have the gasser anymore that was in my signature (signature corrected) and the aux tank does have a manual valve for shutting it off. I have not tried to remove the "T" that is installed in the main tank filler hose but there could be some kind of "float shutoff" in there, it's too big to just be a place to connect a 3/8 line to. From my understanding the original owner has had the truck that way since new, 2008??
GoPackGo
Tim
Nutinelse2do
We have a valve on ours we turn for gravity feed when our low fuel light comes on.
It's nice having the option of getting fuel where we want, when we want, usually without the fiver in tow. Much easier that way, and can get into the smaller stations that are sometimes less expensive.
DH set it up that way to not mess with the truck computer gas thingee.
Sorry, don't know what it's called ๐Ÿ˜ฎ
Cheryl
We have 45 gal RDS aux tank
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
mich800
dave17352 wrote:
mich800 wrote:
fj12ryder wrote:
Okay, now you got me curious.
Why doesn't the auxiliary tank drain into the main truck tank until the auxiliary tank is empty, when the valve is open? Seems like it would if the auxiliary tank is higher than the regular tank.
What am I missing? Surely it isn't just the seal of the fuel cap?
That is how it works. You can get a tee that fits in the filler neck that has a shut off float in it. If someone just connected to the filler neck without some sort of shut off it would flow to the cap.
Yes some people leave the valve open and the cap should prevent any fuel from coming out. I choose to just open the valve when I run low on fuel. In fact with my 50 gallon tank when I open it, it drains far enough down that the level of the diesel is not higher than my filler cap. So it is really a no brainer. I have a 34 gallon tank.
I choose not to trust everything being spill proof around the cap because it is just so easy to flip the lever once. Literally about once every 800 miles or so. No big deal.
I do it similarly. I flip the valve if I am low with no stations in sight or if fuel prices are high. I typically top off my aux tank when I find a good deal and only use it when prices are rising. My own little futures market.
dave17352
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
mich800
fj12ryder
Howard and Peggy
"Don't Panic"
azdryheat
RDS successfully uses gravity fed in-bed fuel tanks. I have one in my truck and it gravity feeds just fine. Do the nay-sayers for gravity feed have any actual experience with the process?
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
dave17352
wanderingbob wrote:
I have plumbed the same way except I leave the valve closed , when the gauge on dash gets low I open the valve and let gravity fill the main tank , If I forget and leave it open , nuttin happens ! Of course me and mickey mouse have only been doing it for fourteen years with no mishaps . Myself I would be afraid of electric pumps and automatic******, manual works for me .
I did exactly the same with my 50 gallon tank, the second time I installed it on my 2011 silverado. Believe me moving that little lever on the valve is really, really easy and it works perfectly. The first time I installed a solenoid switch and a lighted rocker panel switch. It worked too but cost me about a hundred bucks to set up. I agree manual is the the way to go. Piece of cake.
