Dec-02-2014 12:54 PM
Dec-03-2014 01:31 PM
Dec-03-2014 01:19 PM
GoPackGo wrote:I just installed one of these in my buddys new truck last weekend. Works really well.
I have an RDS tank. The RDS install kit INCLUDES a shut-off valve where it plumbs into the main (OEM) fuel filler line. When the fuel level backs up the OEM filler line and reaches the valve, it closes, stopping more fuel from flowing. This way it cannot get up to the level of the outside filler cap.
Northern Tools has the kit. $80.
Tim
Dec-03-2014 11:42 AM
Dec-03-2014 06:03 AM
Dec-03-2014 05:57 AM
Dec-03-2014 03:51 AM
Dec-03-2014 01:26 AM
Dec-02-2014 05:33 PM
Dec-02-2014 04:43 PM
dave17352 wrote:mich800 wrote:fj12ryder wrote:
Okay, now you got me curious.
Why doesn't the auxiliary tank drain into the main truck tank until the auxiliary tank is empty, when the valve is open? Seems like it would if the auxiliary tank is higher than the regular tank.
What am I missing? Surely it isn't just the seal of the fuel cap?
That is how it works. You can get a tee that fits in the filler neck that has a shut off float in it. If someone just connected to the filler neck without some sort of shut off it would flow to the cap.
Yes some people leave the valve open and the cap should prevent any fuel from coming out. I choose to just open the valve when I run low on fuel. In fact with my 50 gallon tank when I open it, it drains far enough down that the level of the diesel is not higher than my filler cap. So it is really a no brainer. I have a 34 gallon tank.
I choose not to trust everything being spill proof around the cap because it is just so easy to flip the lever once. Literally about once every 800 miles or so. No big deal.
Dec-02-2014 04:00 PM
Dec-02-2014 03:34 PM
Dec-02-2014 03:26 PM
Dec-02-2014 03:09 PM
Dec-02-2014 03:06 PM
wanderingbob wrote:
I have plumbed the same way except I leave the valve closed , when the gauge on dash gets low I open the valve and let gravity fill the main tank , If I forget and leave it open , nuttin happens ! Of course me and mickey mouse have only been doing it for fourteen years with no mishaps . Myself I would be afraid of electric pumps and automatic******, manual works for me .
