Axle ratios
brnzbk
I've been looking at new F350's SRW and everything I see has the 3:55 gearing. My intent was to get the 3:73 but apparently I would have to special order it. So my question is: How much am I actually giving up (uphill pulling) going to the 3:55 over the 3:73? The largest fiver we are considering is the Cedar Creek 36 CKTS, about 12K unloaded with a GVWR of 16.5K. If we get that particular one a dually would probably be a better fit and most of them on the lots have 3:73, I'm just not sure we are going to go that large.
Is there a noticable difference between those two ratios when towing?
I know its' a tough question to answer, so many variables, but just a general opinion or practical experience with these ratios would be helpful.
2015 F350 CC LB Lariat 6.7L Dually
2016 Cedar Creek 36CKTS
B&W Companion
19 REPLIES 19
jnphobe
If you can find a dealer to order one as fleet you can get 3.73 gears in a SRW it is a fleet only option
Patti and Jon Holbert
Erie,Pa.
2009 Heartland 3370 Big Horn
2015 Ford F-350 CC DRW 4X4 Ultimate Max Tow 4.30 gears
2012 Explorer Limited Ultimate
1997 Ford F-250 SC 4X4 winter ride & plow truck
Cummins12V98
brnzbk wrote:
Thanks for the replies and valuable information.
I'm going to the dealer on Monday or Tuesday and talk to my sales guy and see what we can put together. I've got my eye on a couple of trucks on the lot, one is a SWR 3:55 and the other is a DRW 3:73, we'll see what happens.
If you think about the future the DRW is the way to go. Every one goes to a larger RV.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
brnzbk
B&W Companion
Javi1
As someone who has pulled the same 12K 5th wheel with both a '12 F250 with the 6.7 and 3:31 gears and a '15 F350 with the 6.7 and 3:73 gears... there is no comparison between the two.. Yes the 3:31's will pull the trailer down the road and at 65mph it will take all but the higher overpasses without down shifting. But get that sucker on the secondary roads and that ain't the case. Even here in relatively flat Texas my F250 spent a lot of time in 5th and a good bit in 4th when the speed limit was 55mph.. The F350 don't.. And here's the kicker.. my fuel consumption went down when I started pulling with the F350.. don't know how it would pull with 4:10's but I expect it would get rolling a bit quicker and downshift a lot less, but cost more in fuel. So, I'm not gonna try them unless I pickup a much larger 5'er and a F450 or F550.
2015 Keystone Cougar 333MKS
2015 Ford F-350XL 6.7 CC, DRW, RWD
(Finally enough tow vehicle 14,000 GVWR 6062 payload)
The_Mad_Norsky
Another agreement on the 3:55 in the SRW Ford.
That new Ford diesel puts out a massive amount of torque and power.
Go for it!
The Mad Norsky, Doll, Logan and Rocky
2014 Ram 3500 w/ Cummins/Aisin
2019 Northern Lite 10-2 EX CD LE Wet Bath
RV'ing since 1991
I took the road less traveled .....Now I'm Lost!
NC_Hauler
rjstractor wrote:
Cummins12V98 wrote:
Ok now which one of us is "Dumb" or "Dummer"
Me like the 4:10's
But it's not an apples to apples comparison- the Ford transmission has lower (higher numerically) ratios is all but sixth gear, so in the first five gears the final drive ratios of a Ford with 3.73 axle gears are very close to that of a Ram with 4.10s. At any rate, the 3.55 ratio that the OP has should move his trailer rather nicely.
Agree the Ford with the 3:55 gearing should do just fine....
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
rjstractor
Me like the 4:10's
2017 VW Golf Alltrack
2000 Ford F250 7.3
NC_Hauler
Cummins12V98 wrote:
NC Hauler wrote:
BenK wrote:
About 9% diiference in torque
Less torque if going from 3.73 to 3.55
More torque if going from 3.55 to 3.73
If MPG is higher in your have to have list...get the 3.55's
If performance is higher on your have to have list...get the 3.73's
I'll always chose performance over MPG...opinions vary...
I for one, agree with you on this Ben....course I'm one of those "dummies" that has a 4:10. I do almost all my towing in the mountains though.
Me like the 4:10's
I said that because someone else couldn't understand why someone would want a 4:10...thus the reason I said it the way I did.....I think we're both pretty doggone smart:)
B&W RVK3600 Hitch
Cummins12V98
Me like the 4:10's
ggardne2
Unless you buy a truck with 20" tires I would stay with the 3.31 ratio, I tow with an F-350 6.7L SRW with the truck maxed out on weight and truck rarely if ever will come out of 6th gear unless pulling a significant grade. Normal freeway grade changes such as overpasses are no problem and the truck will pull them in 6th gear.
Lynnmor
BUUUUUTTTT................. He CANT get the 3.73 in that truck.
The 3.55 will do just fine.
NC_Hauler
B&W RVK3600 Hitch
BenK
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Javi1
If I had that trailer I'd be looking at DRW... 3:73 is kick butt for pulling with the 6 speed.... 3:55 is better than the 3:31 in fact with that trailer the 3:31 will keep you in 4th or 5th at any overpass
