Jan-13-2020 10:39 AM
Feb-29-2020 08:45 AM
jawsthemeswimming428 wrote:Yes I lost track of this myself.
Sorry for the long delay. I found the info on my battery charger (I think). I looked in the fuse box and found the following model info:
WFCO
Model WF-8955PEC
Hopefully this helps?
Feb-29-2020 08:03 AM
So when testing for parasitic draw, do I connect the multimeter to the battery? If there's parasitic draw how do you know which device it is coming from?
Feb-17-2020 04:05 PM
Feb-17-2020 04:03 PM
Feb-17-2020 03:10 PM
opnspaces wrote:
Troubleshooting parasitic draw is usually in how you connect the test leads to the meter. For the amount of draw you are dealing with you can just run the trailer power right through the meter. Your meter should come with a basic instruction sheet for how to use the test functions. If not or if it's confusing, post us the make and model and we can help.
Feb-15-2020 08:19 AM
Feb-15-2020 06:45 AM
Feb-14-2020 04:30 PM
Feb-14-2020 10:28 AM
Feb-13-2020 02:39 PM
opnspaces wrote:jawsthemeswimming428 wrote:
If I went with the 2 6v is there anything else that needs to be done to accommodate other than wiring them in tandem?
You need one additional wire to hook the 6 volts in series. Icing on the cake but not required are 2 new 6 volt battery boxes and POSSIBLY a new charger.
Link to 6 volt battery box
Link to a battery cable
And a strap to make adding and removing the 6 volts a heck of a lot easier.
Linkjawsthemeswimming428 wrote:
Our current setup lasts less than 24 hours with the fridge, on demand water pump, and minimal lights. I think we were given a bum battery by the dealer when we originally purchased. It tested fine but we’ve had nothing but issues.
Maybe it is parasitic draw? Or something else? I’m not too handy with electrical. Is there an easy way to troubleshoot this?
You mentioned the fridge, water pump and lights. If that is all the power draw that you are aware of then yes the battery should last a few days and you have something else drawing down the power. If however you are also running the furnace then that is your big draw. Typically people figure one night of furnace for one battery. So if you have two batteries you should get two nights of furnace. Of course the real determining factor in battery longevity is how warm you set the furnace at night. If it's set for 73 degrees your going to drain the battery a lot faster than if it was set to 63 degrees.jawsthemeswimming428 wrote:
The 2 x 6v setup sounds nice, but we only use it once a year. My TT is a 2016 and does have LED lights. We definitely don’t need the furnace on battery.
If your trailer is a 2016 there's a decent chance you already have a 3 stage charger. Did you get any paperwork with the trailer, maybe an owners manual for the power center with all the fuses and circuit breakers in it? that will probably give at least a model number that we can look up to help you out.
As far as troubleshooting your battery draw. The easiest way is with a digital multimeter. Even a cheap one $7.99 from harbor Freight (free with the right coupon) will help. If you have or can borrow a meter we can help you use it.
And here's a link to a recent battery discussion which has diagrams for hooking up 6 and 12 volt batteries. Link
Feb-11-2020 02:55 PM
Feb-11-2020 01:15 PM
time2roll wrote:jawsthemeswimming428 wrote:2x 6v is not overkill and is for many a basic minimum for off-grid camping. Possibly get 2x G27 from Costco/Walmart but you will not save much or anything.
I am ready to replace my travel trailers factory installed group 24 rv/marine battery. I briefly searched the forum/internet and found a lot of good info but still wanted to post the question with my exact circumstances here. We have a 2016 Forrest River Flagstaff 23LB travel trailer. Most of the time, we camp with shore power. However, there is at least 1 time a year that we camp dry. With the factory group 24 we haven’t been satisfied. Mostly, the 1 time a year we camp dry is in the early fall. We want the ability to use the lights at night (sparingly), the on demand water pump for dishes and showering, and the fridge for a 3 day camping trip. Our fridge will run on propane but from what I’ve read the control board still needs 12v for power.
Would a true 12v deep cycle battery accommodate this? If so, what brand/model do people recommend? If not, what other recommendations are there? I know of the 2 x 6v golf cart battery setup but would that be overkill for once a year? I appreciate any help!
Next issue is your charging system. Many trailers have a converter that just does a trickle charge and you lose capacity from chronic undercharging. Post your converter model for best answers.
Or the battery is often left to discharge in storage between trips giving permanent capacity loss.
Factory stuff generally is not really up to snuff for operating off-grid for more than 18 hours.
Feb-11-2020 01:13 PM
Thanks for the links, I’ll check them out.
Correct, there will be no furnace use on battery power.
I’ll check when I get home later on the paper work for the power center. If not, where would I find the charger? I’m not sure what/where they are usually located? I’d like to put eyes on it to verify the model number if that’s possible.
Jan-17-2020 05:26 AM
