โAug-16-2014 05:24 PM
โAug-17-2014 05:54 PM
โAug-17-2014 05:50 PM
RinconVTR wrote:Huntindog wrote:
Doesn't do much in terms of what? IMO it can only improve things or wont be noticed. It sure wont make ANY condition worse! Actually it could make it worse if a lug plate wasn't used to do the balancing.
Most trailer rims are lug centric, not hub centric. This means that the center hole is not perfectly centered. Using a hub in the center hole to balance the tire will garauntee tat it is out of balance.. Quite possible worse than it was before. Tire shops if they even have lug plates hate to use them. It takes longer. Several times I have asked for lug plates to be used, and watched them NOT do it... One time they admitted they didn't have the right one. When I told them I wanted my money back,,, they got one from another location real quick.
So if you believe in balancing, make sure it is really balanced!:B
โAug-17-2014 05:36 PM
โAug-17-2014 04:49 PM
Huntindog wrote:
โAug-17-2014 02:03 PM
RinconVTR wrote:JIMNLIN wrote:
Tire balance.... not so much.
Mounting a balanced tire/wheel assy on a trailers hub that is not balanced doesn't do much.
More importantly, consider what is furthest from center and has the highest mass. The answer to both is the wheel and tire.
Sure, the drum and hub *might* not be balanced (I'm not convinced they are not) but being smaller, lighter, and much closer to center, I'm not concerned. Nor would this leave to believe I should not balance trailer tires at this point.
โAug-17-2014 01:54 PM
Lynnmor wrote:
Yes, balancing can make it worse or better. If the heavy spot of the tire and the drum were opposite each other, balancing will make it worse. If you never checked your drums for balance, you have no idea and shouldn't jump to conclusions.
โAug-17-2014 01:51 PM
Lynnmor wrote:8iron wrote:
Do people balance their discs and/or drums on their tow vehicles?
They are balanced when made, trailer drums are not. .
โAug-17-2014 01:50 PM
They are balanced when made, trailer drums are not. Folks that never checked trailer drums for balance have no clue.
โAug-17-2014 12:54 PM
โAug-17-2014 12:26 PM
โAug-17-2014 12:23 PM
That depends..
The drum has a much smaller diameter AND MASS than the tire.
Car drums and rotors ARE "balanced", pretty easy to check to see if the drums have been balanced. Typically balancing on drums consists of the manufacturer either drilling /counter sinking into the heavy spot or adding a permanent weight (spot weld) to the light side.
Balancing drums on a trailer is not going to DRAMATICALLY change anything with the trailer due to the small diameter and MAS of the drum,
Balancing the tire on the other hand may or may not make any noticeable change since you are not RIDING in the trailer.
I have run trailer tires balanced AND unbalanced and FOUND NO DIFFERENCE in how the trailer tows or feels. How ever with that said, balancing CAN potentially add some life to the trailer tires since it will REDUCE the BOUNCING of the tires if they are far out of balance.
OK, I understand that you have never checked the balance of the assembly. So why comment?
โAug-17-2014 12:03 PM
โAug-17-2014 11:56 AM
That depends..
โAug-17-2014 11:16 AM
