Bigfoot 25B17.5FB?
Eugarps
All,
I’m considering a small Bigfoot for towing behind my 2013 Toyota 4Runner. It’s light weight would seem to make it attractive for my use. I’m hunting for feedback.
I’ve considered the Oliver buy, even though it’s very nice, it doesn’t fit my budget. The Escape TT’s look nice as well but the Bigfoot seems to be better thought out.
Thanks in advance,
Bill
1978 27' Southwind MH - Gone
1982 19' Terry Taurus TT - Gone
1990 24' Prowler TT - Gone
TC - Still in the Hunt
11 REPLIES 11
wrenchbender
I am very pleased with my Bigfoot
bobndot
marcsbigfoot20b27 wrote:
You will love it. Just used my 18 year old Bigfoot on Monday for some fun.
ref to the OP's original post:
I guess you go "hunting for feedback" too ? quite tasty when marinated.
sorry, i could not resist, and yes, the BF is a great TT . :B
marcsbigfoot20b
rbpru
Same questions. What is the cargo capacity of the tow vehicle? What is the loaded tongue weight of the Trailer? How much family and stuff do you take?
The brand of trailer is a moot point if it has too much loaded tongue weight.
Those Big Foots are sweet trailers that is for sure.
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
John___Angela
TurnThePage wrote:
I'm not thrilled with their design choices in general, but I would own one in a heartbeat, especially up here where it gets cold. One thing I noticed about their larger rigs was the small A/C units. I sometimes wonder if it's up to the task on a hot southern day.
In the 17 foot you don't need much of an AC to turn it into a meat locker in about 10 minutes. In the Okanagan where they are built it gets REAL hot.
TO the OP. Are you planning on doing a custom build or are you going to get something off a lot. (Many go with custom build). Are you going to buy it in Canada or in the USA.
The factory tours are kinda cool if you have the opportunity.
Cheers.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
aftermath
This looks like a nice trailer and should be a good match for your 4Runner. I prefer FB models because where we usually camp, the view out the back is better. Sitting at the table with a cup of coffee in the morning is pretty special. Good luck. Sounds like you are on the right track.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
TurnThePage
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Durb
If you buy the trailer you will love it. My BigFoot 25B25RQ had a brochure weight of 4,800 pounds. Inside there was a build sheet that had weight adds for the options. They added weight for the dual pane windows, the bedspread, the mattress upgrade, the entry steps, the stove burner cover and on and on. The 4,800 pound trailer came from the factory at 5,200 pounds dry. Guess I'm trying to say don't trust the brochure weight. It would be nice to have it weighed but with BigFoot demand you may have to act fast. The BigFoot will be 8' wide so you will need some mirror extensions. The other fiberglass trailers are narrower.
When I sold my trailer (albeit larger) I had to turn away the first three offers due to their insufficient tow vehicles. I felt a half ton truck was the minimum for a 25 ft. BigFoot as mine towed at 6,000 pounds. With a brochure weight less than 2k and a GVW less than 5k I'm guessing the 4 Runner will handle it pretty well assuming you don't get carried away loading it up. Good luck. Fine trailers.
gmw_photos
Very likely could be set up to tow nicely, but will require careful set up with a quality WD hitch to work well with the four runner.
EDIT: correct me if I'm wrong OP, but as I recall the 2014 four runner is a body on frame chassis ?
These 4.0L V6 gas engines seem to hit a real sweet spot in overall use as well. If so, a very sturdy platform from which to start.
For some setup help you could check with Can-Am RV if you have questions.
John___Angela
Well built product. Excellent reputation. Built 12 km from my house.
drsteve
How small is small?
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
