Break Away Cable
CavemanCharlie
I need a new cable for my Break Away Switch. The switch has ESCO printed on the top of it. I can't seem to find a match for that. I'm guessing it interchanges with one of the other brand names. Which brand name does it interchange with ??
Thank-You
(P.S. when I say cable by that I mean I am looking to replace both the cable and the plastic key thing that it is permanently attached to.)
19 REPLIES 19
Grit_dog
Navigator
Navigator
JRscooby wrote:
I fail to understand. I have been known to work on hot 120V circuits. But if somebody feels the need to ask about disconnecting they might not have a firm grip on how to work safely.
Statement of the day!
mobeewan
JRscooby
I think if you read my first reply I suggested not only disconnect the battery, but also disconnect the neg post of the battery.*
If there was any snark in my comment, it was directed at the person that bragged to somebody that was not sure, that he could change the switch without issues. I have no problem with somebody asking, but IMHO, if you are going to tell how to do it tell don't assume the person asking already has the skillset not to cause a short.
*The reason I say (-) is if the (-) is hooked up, and a wrench gets between frame and (+) post there will be a big arc. Post>wrench>ring>frame can take a finger. And that big arc that close to battery can cause battery to explode.
Gdetrailer
Not so much about having a "firm grip", but more about at least asking a very smart question before jumping into a potential pool of sharks.
As a Electronic Tech of way too many yrs, I have worked on "hot" chassis" electronics from tube radios and TVs to even more modern solid state TV chassis up to the 1990s.
I can say I would rather have someone ask this question that you might consider dumb and get a good honest answer without a snarky reply.
The honest and best answer is to always remove power before proceeding with messing with any wires unless power is required for troubleshooting with test meters.
Never "assume" it can't hurt you or cause other damage.
12V is generally considered "low voltage", it does still have potential to do some damage. Breakaway systems may or may not have a fuse (one of the few times fusing rules are relaxed) due to the fact that they must operate in the case of an emergency and a blown fuse can render the system inoperable condition..
One side of the switch will be wired "hot" directly to the battery, the other wire goes to the electric brake wires so you have a 50/50 chance of shorting the battery side to ground accidentally and if not noticed quickly can over heat the wire..
valhalla360
Nomad III
Nomad III
Take the 30 seconds to disconnect the battery.
No you probably won't kill yourself or blow up the RV but it's good practice to not work on live electrical systems.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
JRscooby
GrandpaKip wrote:
I replaced mine without unhooking the battery. Just make sure not to touch bare wires together.
wnjj
Equally important is not to let the bare wires on the trailer touch the frame. One of them is connected directly to the battery, and probably not fused.
Gdetrailer
Thank-You
According to HERE..
"We have found that the pin on the Replacement 48" Cable for Breakaway Switch 54-85-002 does fit many models of ESCO breakaway systems.
It is designed to fit the Bargman Breakaway Switch 54-85-007 and not an ESCO system but based on your photo and the pin on the cable I would be surprised if it did not fit."
However, with the price of that cable being about $5 you are not saving a lot of money over a new complete switch and cable. Breakaway switches do fail since they are exposed to water intrusion 24/7 so it isn't a bad idea to just replace the entire switch assembly since you need the cable and pin anyways..
I like to keep a spare switch and cable on hand myself.
GrandpaKip
The Keys are usually not interchangeable ....just buy a new Break Away Switch with Coiled cable
Simple......
When I go to replace the old switch will the brakes be applied when I un-wire the old one ? Should I unhook the battery first ?
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
JRscooby
Simple......
Generally, when working on the electrical system it is a good idea to disconnect (-) from battery. Not likely to get shocked, but burn is more likely.
Any time messing with break-away you should unplug the light cord to be sure you don't feed backwards to controller. May not harm, but a real low payout compared to risk on that roll of dice.
That said the break-away switch is a normally closed switch held open by the pin. As soon as a wire is disconnected the circuit is open, will not harm brakes.
enblethen
you will be better off to:
1 Remove mounting bolt from old
2 bolt new one in place
3 lay out wires along old ones
4 cut the wires off of the old switch, one at a time.
5 splice the new switch in.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
CavemanCharlie
Simple......
deltabravo
rlw999 wrote:
Those unknown Chinese brands on Amazon always make me nervous.
Ditto. The one linked above is a knock-off of the one Fastway has been doing for about 8 years or more.
I use the Fastway brand and love them.
You can get the tether and a new unit or just the tether.
https://www.amazon.com/s?k=fastway+breakaway+cable&i=automotive&crid=2WZPG9EDBVHHK&sprefix=fastway%2Cautomotive%2C463&ref=nb_sb_ss_ts-doa-p_5_7
ScottG
Yeah, you shouldn't get one.
