โNov-16-2016 07:15 AM
โNov-17-2016 08:18 AM
โNov-16-2016 07:01 PM
โNov-16-2016 04:52 PM
โNov-16-2016 03:13 PM
โNov-16-2016 09:35 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โNov-16-2016 09:08 AM
Grit dog wrote:
If you've ever driven a srw pickup with a big long heavy camper (or just heavy) I think you'd find that if you're in situations where departure angle is an issue, stability, gradeability and tire/suspension damage will be of concern before dragging @ss going through a creek bed.
On board air system is not a great bang for the buck for this condition IMO.
You're not going to get much more height than whatever your "correct" ride ht/suspension engagement is for normal stable travel.
If you plan on really off roading with a camper, IMO concentrate on having more truck than you would normally need for a given camper and find a model with that isn't enormously longer than your truck bed, but more importantly doesn't drop down vertically behind the trucks back bumper.
Example, my AF camper, while maxing out my truck payload wise and overhanging the back of the bed almost 3' has a good departure angle for what it is because there's no vertical overhang to reduce vertical clearance. I've run it out on some gravel bars on the Copper river and had no clearance problems with dips, holes, river banks. My limiting factors were not breaking, bending, tipping or sticking a 12000lb rig in the middle of the river in remote territory. An ideal setup for those trips would be a camper, even of the same length, but considerably lighter, or a much heavier suspension/truck than stock springs and airbags.
โNov-16-2016 09:03 AM
Reddog1 wrote:
Wikel, I think you have it figured out. I think the ability to use or not use the air bags is great. I suggest using the air bags with built in bump stops. They are less likely to get be damaged when running without air.
Wayne
โNov-16-2016 08:33 AM
โNov-16-2016 08:06 AM
Toad: 91 Zuke
โNov-16-2016 07:41 AM
โNov-16-2016 07:28 AM
โNov-16-2016 07:23 AM
