Chevy LT4 small block is a torque monster
8_1_Van
The crate engine is $16,819 MSRP and should offer it as an option in Chevy trucks since it has tons of low end torque.
specs
11 REPLIES 11
Lessmore
Chuck_thehammer wrote:
same reason the "409" was not a good anything engine.... died 1965...
mainly the engine block... keep crankshaft in line.. and keep head bolts from being pulled out..
and the reason there were (2) 427 engines..
427 Tall block (Truck)
427 standard block (Car)
The 409 was a good engine for it's time. It was a hard running drag engine that won some National championships. It was also a well regarded high performance, street engine and used in medium and medium heavy truck applications.
I emphasize for it's time...if you look at criteria such as engine durability, power, torque, noise, vibration, harshness...the 348/409 W series V8 was a good engine.
You cannot compare any engines made 50-60 years ago with modern engines. Technology has marched on at a rapid rate...so much so that a modern engine, eclipses decades old designs.
rjstractor
8.1Van wrote:
It would have about 600 ft lbs tq highway speed in OD with a 3.73 rear and 31.5" tire like the LT265/75R-16 with much left over for passing and climbing. At high altitude it would not lose as much power as a non supercharged engine. I bet it could be modified for truck (LT4HD ?)use to lower the high rpm HP but keep the low end torque. The 8.1 has 450 ft lbs tq @3200rpm vs LT4 having over 600 ft lb tq @3200rpm or 450 @1000rpm.
Basically an Ecoboostish V8, only supercharged rather than turbocharged. Torque and hp specs would no doubt have to be rolled back to be able to stand up to a HD pickup duty cycle. 450 hp/550 torque would be pretty doable I would think with an iron block. Towing mileage would be horrendous but you could go about as fast as you want. Still would be hard to compete with modern diesels that go over 400/900 with much better towing fuel mileage and good longevity.
2017 VW Golf Alltrack
2000 Ford F250 7.3
kw_00
Chevy really makes some impressive small block LS based engines. This would be a cool engine to throw in a classic C10 if your upgrading the original drivetrain. It will be interesting what performance goodies that GM does with their HD 6.0 engine in the future. I mean the engine is awesome but I see direct injection within a year or 2.
A truck, a camper, a few toys, but most importantly a wonderful family.
FishOnOne
It yielded a good song
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
8_1_Van
Dannyabear1
A good ole 8.1 is truly the torque monster
travelnutz
Chuck_thehammer,
Engine technology, materials, and alloys have changed so much since those engines were designed and made. No comparison. The major consideration for any work engine is at what RPM do you want the maximum torque (rotational twisting force of the engine's crankshaft) at?
It's torque that is the force that turns the wheels to any RPM's at all and what moves the load to the desired velocity!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
Chuck_thehammer
2003silverado
I understand that particular engine and the 6.2 aren't heavy duty engines, but why couldn't they easily be? I am truly curious as to why GM can't take the 6.2 with its technology and give it a stronger crank, an iron block etc, and use it in the HDs.
The engine in the original post would blow the pants off the current diesels in towing comparisons.
Dannyabear1
You cannot make some people understand that this and/or the current 6.2 is a 'hot rod' engine not designed for towing, hence it is not available in 2500/3500 trucks
BenK
Yes, a fantastic ICE...but it is still in the same class as the small block 6.2L
If it has the duty cycle of a working truck engine, then really something !!!
Otherwise, just a car engine stuffed into a truck...just like the current 6.2L aluminum block
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
