Chevy Silverado V6
Big_steve
Looking for Tow vehicles. Came across a 2012 4D Chevy Silverado Extended Cab 4.3L 195 hp 6 Cyl. Both the manuf and a towing web page claim it can tow 9700 lbs! With 195 hp?? Anyway, calculated max capacity with loaded trailer, truck payload, water, etc... and it does come in a little higher (not a lot) than what I would need.
Still, I can't see how that engine can pull me up some mountains in Ga and the Carolinas.
Am I wrong? It's a decent deal.
Thanks
13 REPLIES 13
blt2ski
Moderator
Moderator
If you want a 4.3, get a 2014 or later model. Those are around 300 hp and lbs of torque. This is a redesigned 4.3 vs the 2013 and earlier models, as noted a 350 with 2 cylinders lopped off. I had a tbi and a vortec version in Astro vans. The vortec was a beast vs the tbi. Still, I would not want to tow over about 4-5000 lbs with it. I've been looking at the 14 and newer ones. With the 6sp auto, It would do ok with upwards of 6-7000 lbs. Won't be the quickest thing on the block, but still do what I would call, reasonably well.
Marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
Greg_B
Had a 4.3 in a work truck back in the 90's that had 200 horse. Good solid motor but not well suited for towing. Its unbelievable the same motor in 2012 would actually have 5 HP less.
04 Dodge 1 ton dually, Cummins, auto, quad cab, 4x4, SLT, Sport, Reese Titan V
04 Lance 1161, TV/DVD, high efficiency A/C, Honda EU2000
trail-explorer
Skip the 4.3 That engine has been around since the late 80s / early 90s.
It's old skool - essentially a 5.7L with the back two cylinders whacked off.
Bob
Lwiddis
I wouldnโ€™t go over 6k with my 5.3L V8 so Iโ€™d never consider a Chevy 6.
ib516
Are you sure it's only 195hp? I thought the V6 had more beans than that....
ON EDIT: I googled it and yep...a whopping 195hp. Wow, welcome to 1992, er, I mean 2012 GM.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
Big_steve
DBH_MI wrote:
The owners manual says the 2012 Extended Cab V-6 with 3.23 axle is rated for 4400 lbs.
I figured it would be less. I was just floored when two different sites said that engine could do 9000 pounds.
Big_steve
Grit dog wrote:
In a separate topic, at the same time basically you asked about 5ver vs TT.
That thread, with respect to this thread is like oil n water. Truck you're looking at won't even remotely work for the trailers you're asking about.
If it matters, I'm trying to decide between Class C, TT, and based on what I read on the 5ver thread, no longer considering a 5th wheel.
Grit_dog
Nomad III
Nomad III
DBH_MI
ktosv
That most likely is the gross combined weight rating (GCWR). Max tow rating for that engine was around 5000# in that vintage Silverado.
What size trailer do you have? If that truck was a 2014 or newer with the 4.3L it would be much more competent.
Kevin and my...
Wife and six kids
2017 Suburban (5.3L/6A/3.08)
6x12 Enclosed Utility
Sold...2011 Express 3500 (6.0L/6A/3.42)
Sold...2010 Passport Ultra Lite 2910
Grit_dog
Nomad III
Nomad III
Youโ€™re right. That ainโ€™t the truck to tow 9700lbs with and itโ€™s absolutely not rated for that much either, so you got some bad intel.
Donโ€™t fark around with the low end base engine half tons of youโ€™re towing more than a pop up or canned ham trailer. And even then the performance will be lackluster.
ShinerBock
Tow capacity is not on the yellow sticker. That is tire and loading payload sticker based on stock tires which goes out the window if you change out tires to something with a different load rating.
2014 Ram 2500 6.7L CTD
2016 BMW 2.0L diesel (work and back car)
2023 Jeep Wrangler Rubicon 3.0L Ecodiesel
Highland Ridge Silverstar 378RBS
romore
What is the tow capacity on the yellow door sticker? That is the rating for this particular truck. We tried towing with a 4.0 liter V-6 Ranger in the B.C. mountains, after two trips we had enough. The trailer was within the limits according to Ford but somebody had obviously never tried it. Save your nickels for a more capable vehicle.
