โOct-30-2020 04:55 AM
โNov-05-2020 06:05 AM
โNov-02-2020 04:33 AM
CavemanCharlie wrote:valhalla360 wrote:
Unless you have an issue...I wouldn't worry about it. Who cares if there is a little crud on the inside of the tank? Now if you have a pile of poo under the inlet, that's an issue.
Two habits to get into:
- Avoid dumping unless at least half and preferably 3/4 full. That will allow the poo to float and provide enough flow to carry it out.
- Put a few gallons of water in before a drive. The sloshing around will knock any larger deposits off and the next poo deposit will be floating and not stuck to the bottom.
This is what I do .
โNov-01-2020 03:55 PM
โNov-01-2020 03:54 PM
โNov-01-2020 03:48 PM
โNov-01-2020 02:32 AM
โOct-31-2020 06:46 PM
โOct-31-2020 08:11 AM
wanderingbob wrote:
The easiest way to clean the tank is to take a drive . Back when we stayed in campgrounds we would not dump when leaving a campground , we would dump upon arrival at the next campground . The sloshing around did the job and there was never any line at dump spot .
โOct-31-2020 06:44 AM
โOct-31-2020 06:14 AM
โOct-30-2020 06:36 PM
โOct-30-2020 12:29 PM
โOct-30-2020 09:02 AM
โOct-30-2020 08:41 AM
