Sep-30-2014 07:21 AM
Oct-02-2014 06:08 AM
nm1oqrz wrote:
Hello fellow campers. Lance campers have a battery isolator that is between the truck and camper that will disconnect the charge wire if the truck battery falls below a specific voltage. On my 08 1055 it is located inside the stepup to the overhead bed. If this doesn't work properly and things are on in the camper it will also drain the truck battery. Lance has been using these isolators for several years.
Happy camping nm1oqrz
Oct-01-2014 06:43 AM
Oct-01-2014 05:28 AM
BugsRLB wrote:
I am assuming if there is some kind of solenoid (I did not install one)that it is possible it could have gotten hit by the strike.
Oct-01-2014 05:10 AM
tony lee wrote:
Is it possible that you have a problem with the truck alternator and it is not charging the start battery as it should be and in fact your whole rig was running off the camper instead of the other way around.
Sep-30-2014 05:50 PM
Sep-30-2014 04:39 PM
BugsRLB wrote:
And, the TC was plugged in to shore power when is sucked the truck batteries dry in our driveway.
Sep-30-2014 10:20 AM
Sep-30-2014 10:04 AM
Sep-30-2014 09:52 AM
Super_Dave wrote:deltabravo wrote:Super_Dave wrote:
Yes, there is an anti-suck relay between the battery and the truck plug in the bed of the truck.
GM doesn't install one.
But his camper dealer should have. This problem appears to be new since the truck was hit by lightening and not previously an issue.
Sep-30-2014 08:30 AM
Sep-30-2014 08:17 AM
DWeikert wrote:
There's nothing stock on your truck to isolate the truck and camper batteries.
Sep-30-2014 08:06 AM
Sep-30-2014 07:25 AM
