โOct-22-2013 07:50 AM
โOct-23-2013 08:39 PM
โOct-23-2013 07:15 PM
wmoses wrote:Gdetrailer wrote:
I would think that making a DIY double panel like OEM would be a bit of a stretch so I would think you are going to have to settle on single pane.
Isn't that the reverse of what he has? I believe he has a one-piece and some are advising that a two-piece would be easier.
โOct-23-2013 06:30 PM
โOct-23-2013 05:06 PM
โOct-23-2013 02:57 PM
dodge guy wrote:
Sorry, i said glass. I meant plastic front window.
โOct-23-2013 02:18 PM
โOct-23-2013 10:51 AM
โOct-23-2013 07:26 AM
dodge guy wrote:
No metal frame. It was a 2 piece glass (picture a thermo pain) and was sealed at the ends and had a rubber weatherstrip/seal around it that sealed to the trailer, this is where they leaked and why the OP had to repair the front wall. I had a 93 Award 727 trailer and it had A small leak at the front that i stopped before it caused any damage! They are excellent towing trailers to bad they were plagued with the water leak issue!
I would get a piece large enough to cover the opening and then heat it to conform to the contour of the front, IIRC it was only rounded side-side not up/down? Then maybe build some kind of frame to hold it and screw that into the opening?
โOct-23-2013 04:08 AM
โOct-22-2013 08:16 PM
beemerphile1 wrote:
Unless it is important to retain the original design I would do one of two things.
1 reframe with a center post and install two standard flat windows.
2 reframe the whole area flat and install one large flat window.
โOct-22-2013 07:03 PM
โOct-22-2013 06:12 PM
โOct-22-2013 04:20 PM
โOct-22-2013 02:01 PM
naturist wrote:
Methyl hydrate, aka methanol, does nothing to/for acrylic sheeting (Plexiglass being a trademarked brand of acrylic sheeting). Methylene chloride, aka dichloromethane, is the solvent used to bond acrylic sheeting.
