โJun-21-2004 09:12 PM
We are getting closer to answers I am looking for etc.
โFeb-27-2013 08:16 AM
Jarlaxle wrote:transamz9 wrote:bankcardrep1 wrote:
Speaking of a suitcase full of money, I just spent 2300.00 on four injectors for my 06 Duramax. Need to be prepared for 4 more. Love it, but thinking a big block will be my next tow vehicle.
Need to learn how to do the work yourself. It's simple stuff. I just spent $1800 doing my FIL's '03 D-max and that was for all 8 with a 2 year warranty.
JUST THE INJECTORS are $400 EACH, and that's for the cheapest available ones! (Delcos are more.)
โFeb-27-2013 07:45 AM
โFeb-27-2013 07:34 AM
โFeb-27-2013 02:47 AM
โFeb-27-2013 01:46 AM
โFeb-26-2013 06:03 PM
transamz9 wrote:Taco wrote:
So now you have to be either rich or a mechanic to own a new diesel.
A few decades ago the big rigs were gas powered and they seem to get the job done so I suppose with the right transmission and rear end the v10 would do just fine with 38k provided you were willing to buy the fuel.
If you consider a 7 year old truck a new truck then yes you better become a mechanic. Changing the injectors on a motor is hardly a mechanic.
To give a little story about the so called mechanics at my local F dealer. I called the service department one day to ask a question about checking the cylinder pressures on a 6.0 diesel. The response I got was to pull the spark plugs and use a compression tester. ๐ This is a true story, cross my heart and hope to.....
I called parts for a crank case breather for the same motor and was told they didn't put one on the 6.0.
So , pay $100 an hour for that kind of service or do it myself? It's not rocket science. Most people on here are rocket scientist anyway, surely they can remember righty tighty lefty loosie.
How much did it cost to have the plugs changed in a Triton 5.4 when the plugs broke off in the head when changing it? What about when it blew the plug out of the head and the head had to be replaced?
โFeb-26-2013 04:13 PM
โFeb-26-2013 03:45 PM
โFeb-26-2013 06:36 AM
โFeb-26-2013 05:50 AM
โFeb-26-2013 05:27 AM
โFeb-26-2013 04:33 AM
โFeb-26-2013 04:28 AM
bkirkpatrick wrote:Jarlaxle wrote:but spinning the RPM's to keep up with the diesel(low RPM) is going to kill the V10 over time.rvert10 wrote:
According to the tow chart the 550&V10 should pull up to 17,300k
18,300lbs, actually.
Mileage will be about the same as a new emission diesel hauling that weight: lousy. Comparing two tow trucks, an F-550 V10 and a Ram 4500 with the Cummins, the mileage is a wash...despite the F-550 being a Supercab 4x4 and the Ram a regular cab 4x2. Of course, fueling the Ram is $4.15/gallon and fueling the 550 is $3.75!
โFeb-26-2013 03:11 AM
โFeb-26-2013 02:18 AM
