โMar-29-2019 07:12 PM
โMar-30-2019 05:17 PM
AnEv942 wrote:
Ya the droopy body-
the '98 F250 was a transitional truck as mentioned, F150 body, though if I understand correctly it was sold for couple of years (with new body, lighter components) along with the new F250-SD in commercial/fleet truck lines.
98 is when I decided going in the direction of a TC- I was dreading that new SD trucks would have the droopy body. Fortunately not, though not the OBS which imo last good looking truck.
As noted Hellwig does offer a S/B, Both H/J and T/L list tiedowns (H/J thouhg shows the front body button not ear mounts?). Air lift and firestone list air bags, (though 2/3000lbs assist).
Sway bar not required but most will see improved on road handling, especially with a tall load. I don't know the weight of the SixPac hardside but that would be 1st consideration. S/B would minimize sway if noted but not compensate if over capacity.
As far as the H/J bumper bracket a brace tying to frame can easily be fabbed to help with bumper twist, or possibly the one they sell might be modified to work.
โMar-30-2019 10:17 AM
โMar-30-2019 09:54 AM
โMar-30-2019 09:44 AM
...1998 was an oddball that looks just like an F150. ...Are those the body styles that look like they were a normal Ford but left in the sun too long and they started to look "droopy" ...almost as if Salvadore Dali was the designer?
โMar-30-2019 09:27 AM
โMar-30-2019 09:01 AM
โMar-30-2019 08:10 AM
KD4UPL wrote:
I'm not sure why you think an anti sway bar is so vital. I carried an 8' pop-up camper on a '96 Dodge 1500, an 11' 4,000 pound Fleetwood camper on an '07 Chevy 3500, and the same camper on an '05 Chevy dually. None of these trucks had anti sway bars. I don't remember any truck I've ever owned in the last 25 years having one. I never felt that one was needed, never crossed my mind. I did have air bags on all 3 trucks.
โMar-30-2019 07:49 AM
โMar-30-2019 07:43 AM
โMar-30-2019 04:59 AM
โMar-30-2019 04:18 AM
sdbackout wrote:
Regarding the anti sway bar, I have looked online and was not able to find an aftermarket kit. I called my local auto parts and nothing came up on their system.
โMar-29-2019 09:24 PM
d3500ram wrote:
Welcome!
A sway bar will help a lot and it should be highly considered. Perhaps some good aftermarket shocks as well. Six-Pacs I believe are relatively a lighter weight camper compared to most of the members here. A 250 has at least some good components of which might need some basic modifications... but conventional wisdom says to put the camper on the truck and then decide if suspension upgrades are necessary.
There are two popular ways to attach the camper. The bumper to which you allude is part of a brand called Happi-Jac. This method of using the bumper as well as hardware that includes a tab that sticks out between the front of the bed and rear of the cab allows fasteners to attach from camper to truck. If the bumber is not that stout, I believe that HJ has stiffeners that can be added to the stock bumper. I do not own this brand and am not as versed in it specifics.
Another brand is Tork-Lift. This style utilizes steel brackets under the bed that are fastened directly to the truck frame. There are inserts into these tube-brackets that stick out under the "rockers" of the bed to which fasteners connect the camper to truck.
In either style, it is better to use spring loaded fasteners over the old style of just chains and turnbuckles.
โMar-29-2019 09:11 PM
hornet28 wrote:burningman wrote:
There were sway bars in the โ90s and way before then.
The โ98 F250 is an odd one-year truck with the whole F150 body and F250 running gear
How is the body supposed to be different between the 1/2 and 3/4 T?
โMar-29-2019 08:13 PM
โMar-29-2019 08:08 PM
