โApr-12-2018 05:53 PM
โApr-15-2018 01:17 PM
Retired JSO wrote:
Skip the gas unless you can find a lower gear than the 3.73. My 16, 6.2 canโt maintain 65 with any headwind over 12-15 mph in 5th towing my 25โ W&P at 9,200 lbs. iI drive in 5th most times towing but a headwind is like putting on the brakes.
โApr-15-2018 10:52 AM
โApr-15-2018 10:00 AM
โApr-15-2018 09:32 AM
4x4ord wrote:
An f150 is quite likely a good choice for someone wanting to tow a 10000 lb trailer with a gas engine. If I wanted more truck than a f150 I would buy a f350 diesel. If the diesel was out of my budget I would buy a slightly used 2017 f350 srw diesel.
โApr-15-2018 09:29 AM
burningman wrote:
Like was mentioned, itโs a tool you buy to get a job done. It might last longer if it sits in a garage and only carries groceries home every other week, but itโs made for working and it can do it.
โApr-15-2018 08:49 AM
โApr-15-2018 08:24 AM
โApr-15-2018 07:41 AM
time2roll wrote:
No strain. It is just a machine and does not get tired.
โApr-15-2018 12:21 AM
โApr-14-2018 08:25 PM
โApr-14-2018 08:15 AM
โApr-14-2018 08:03 AM
โApr-14-2018 06:38 AM
Grit dog wrote:ppine wrote:
A lot of the strain is expressed as heat. Transmission fail and engines blow up because of heat a lot of the time. Even with a large cooling system and a trans cooler it is possible to overheat the drive train shortening its life. This is especially true on mountain roads and small secondary roads with much steeper grades than interstates and state highways.
Correct, but reel yourself in from left field now. Let's stay on topic class! Lol
โApr-13-2018 10:13 PM
georgialawn88 wrote:
I just meant extra strain. Like I'm not gonna blow up the motor pulling that. This will be a new 2018 f250 when purchased
