It is encouraging to see I'm not the only one with the issue. Your comments were insightful and your progression of logic has led me to appreciate the root cause that I think the last 3-4 posters were getting at(I'm a mechanical engineer). First, to answer some questions raised:
WEIGHT - our trailer has two 3500 axles, GVWR of 7660, and we routinely travel at 7400 lbs. The frame is probably built to a price point so we are right at the limit but not past it.
WHY WORRY ABOUT LEVEL? - Refrigerator is the main concern but as someone pointed out 1/2 " off is likely close enough. Self-bailing shower with hard sides is a compelling problem because just a little off level will wet the floor. Of more pressing importance is my wife's uncanny ability to sense 1/64" off level from 5,000 yards away.
THEORY OF RELATIVITY - Complicating the situation with my wife and the hardware is that there doesn't seem to be a single surface in or on the trailer that is level with the world. As one poster mentioned, we use the bathroom door as the final indicator - if it will stay in whatever position you put it, the boss will agree it is "close enough". I even modified the dinette table to be free-standing with three adjustable legs so it can meet her sense of level in any situation(the things we do for love.......and tranquility).
SPRINGS - as one poster said, we are still sitting on the springs of the trailer as the stabilizer won't lift the trailer off the springs (that's how I bent the leg). We can feel our trailer bounce with each step when we walk. I recently fabricated two hard supports from a threaded rod, nut, and sleeve that I place in the middle of the frame and down to a good ground support and tighten with a wrench. This totally eliminates the suspension bounce when we walk.
LIKELY CAUSE - When I replaced the front stabilizer I took the old one apart to see how it works and to salvage the other good leg so I don't have to buy the whole assembly next time. This mechanism actually slides within itself so that an equal force is applied to both legs regardless of the height of the surface under the trailer. That is, if you put 3 blocks under the left side and one block under the right side, the mechanism shifts and applies equal force on each leg.
This sliding characteristic creates a virtual pivot point as the load changes side to side. Your comments led me to realize that it is this very pivoting of the stabilizers under load that lets the trailer tilt, as they are basically just a one point support. As others pointed out, if I had independent jacks at each corner this would not happen. So, my frame is probably not flexing beyond reason and this is probably a sacrifice to having this type of stabilizer.
Good job with the comments! My next post will be seeking help on solving differential equations, so start reviewing!!!!
Thanks.
2013 Tundra, 5.7FF, TRD, 4WD, tow pkg
2014 Forest River Cherokee 264
Prodigy II / Equalizer 10K
103 nights & 12,700 miles since April '13
