Draining fresh water tank
Kylesmith3021
Went to drain fresh tank after sanitizing it and its literally a small valve that takes over an hour to drain..Am i missing something here?? Its located under trailer below water fillup
25 REPLIES 25
myredracer
duplicate...
myredracer
If you have an outdoor shower you can run the pump at the same time. Also pumping into the grey tank at the same time should help providing you can dump the tank where you happen to be.
If you need to do this often, I wonder if it would help to install a 1/2" to 3/4" or 1" PEX coupling and a ball valve for better flow. I installed a tee and valve right at our pump so I can attach a hose directly at the pump - pumps water out somewhat faster than using the outdoor shower or a faucet. Nash has a good setup for fast draining.
coolbreeze01
A 2 1/4" to 2 1/2" knife drain is normal and doesn't take long. Anything less is substandard and just plain cheap.
2014 Sandsport 26FBSL
rockhillmanor
Yup that's normal. A teenie tiny opening to drain the fresh tank.
If I am in a hurry I just open up the "cold" kitchen faucet full force if I want it to drain into the gray or open up the "cold" bathroom faucet which empties into the black. This is done with the water pump on not shore station water hookup.
If you are doing this at home I'd pick what ever faucet drains into the gray tank so you can dump the now filled with fresh water gray tank.
Using the coach faucets really cuts the time it takes to drain using that darn small gravity drain valve.
Nunyadamn
I will pump it into the grey tank. It takes forever if I don't for the 80 gallon tank. Takes about 15-20min by using the pump.
2014 Jayco Jayflight 32BHDS
2015 Ford F250 Lariat 4x4 Crew Cab 6.7L Powerstroke
NanciL
Sounds weird to me.
I have a 2006 travel trailer with a 55 gallon fresh water tank.
It has a gate valve and will empty in a few minutes.
Are you sure you didn't just open the low point drain?
jack L
Jack & Nanci
pconroy328
I've got a 55 gallon - and it's a long process too. ๐Ÿ˜ž
Dirtpig
How northwood does it, with a 2.5" pipe with knife valve. Can drain tank in less then a minute. Handy for sanitizing water system. I know the feeling of having to wait 30min for your tank to drain when sanitizing! Our last 2 campers had small drain hoses, i imagine this is to reduce cost.
2015 Nash 25C bumper pull /w 300watts solar my install
My Truck & RV youtube channel
2005 F-350 Diesel 4x4 CC SB SRW
2001 Honda XR400: many mods
12ft Lund WC boat & 9.9 Yamaha 4 stroke on custom loader.
Sprink-Fitter
We have a 150 gallon tank, it takes a very long time to drain it.
2006 Coachman Adrenaline 228FB
2012 Can Am Commander XT 1000
RoyF
Second the motion; it takes that long if you have a 60 or 80 gallon tank.
TucsonJim
No, that's pretty normal. My last two rigs had the same thing. My current one has a gate valve and I can empty a full tank in about two minutes.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
