Apr-07-2022 09:46 AM
Feb-28-2023 01:07 PM
Feb-28-2023 12:00 PM
mbloof wrote:Lantley wrote:
There is always friction between road and tire.
One of the reason cars cannot stop on ice is there is no friction between tire and ice.
Sure the brake pads stop the wheel but on ice the wheel does not stop the vehicle.
Eliminate the ice and the vehicle is able to stop.
Forgetting for the moment that it is the friction between pads+rotor that ought to be slowing/stopping rather then the tires themselves here's what I had exception with:
"My dually also has more braking power, it certainly stops my trailer much faster the my SRW trucks. Again this is determined from the drivers seat not from the text book."
I'm simply pointing out that for 1T trucks the SRW and DRW have the same pads and rotors IE: SAME BREAKS.
Any implied or imagined extra stopping "power" is NOT from the breaks.
- Mark0.
Feb-28-2023 11:37 AM
Feb-28-2023 11:25 AM
Feb-28-2023 07:39 AM
Feb-27-2023 06:20 PM
mbloof wrote:StirCrazy wrote:mbloof wrote:Lantley wrote:
No dog in this fight but actual experience always supersedes text book theories
My dually is more stable than my SRW trucks.
Is it the out rigger effect or is it stiffer sidewalls? Does it matter? From the drivers seat I can feel a noticeable difference.
Funny as if you look at the actual part numbers for the DRW and SRW breaks guess what?
They are the same.
So much for "seat of the pants" theories... 🙂
Enjoy your DRW, for whatever reasons you have.
- Mark0.
your forgetting a few things, there is twice as much rubber touching the ground in the back so twice as much friction against the road.
in your previous post about spring mounts being narrower vs side walls if that was all that was inolved you would be right but DRW also have a heavier spring pack so theres that also you forgot about..
I have a SRW myself but there are times I wish I bought a DRW just for the higher load carring capacity.
Your forgetting that the width of the tire(s) has no bearing on the breaking distance - until they begin skidding - THEN the increased friction of the wider tire patch comes into play.
You also failed to read my prior post. I mentioned having the SAME springset (and assumed same mounting position as there is no difference between SRW and DRW trucks when it comes to spring pack location).
Yes SOME (not all) DRW's have heavier spring packs. Keeping in mind that almost ALL camper owners modify their suspensions regardless if they have a DRW or SRW AND most would not buy a DRW simply for the stiffer springs IMHO your point is moot.
- Mark0.
Feb-27-2023 04:08 PM
Feb-27-2023 12:07 PM
jimh406 wrote:
Warning .... some satire follows.
SRWs are just as stable as DRWs and brake just as well. Springs are the same as well. That's why the DRWs have more payload. You could get the same payload by doing a second tire on each side with a kit. You can ignore everything but the tires/wheels.
There are no brake differences. Brakes are just discs and pads. It doesn't matter that DRWs don't usually have the same calipers as SRWs. Calipers don't matter. DRWs also are rated to tow more even though the brakes are identical.
The disc diameter is different on F450s and up compared to SRWs. Doesn't make any difference. They might use the same brake pads.
No satire follows ...
There could be a conspiracy to convince people to buy DRWs. Or, there may be something to the differences since so many people can tell the difference and note it.
Finally, buy what you want, but don't make things up to try to justify your reasoning. There are good reasons to buy a SRW just like there are good reasons to buy a DRW. YMMV.
Feb-27-2023 11:50 AM
Feb-27-2023 09:46 AM
They are the same.
- Mark0.
Feb-27-2023 06:37 AM
Feb-27-2023 05:19 AM
They are the same.
- Mark0.
Feb-26-2023 08:01 AM
SoonDockin wrote:
I feel more tires is better, also bigger is better. Its why I went from a F350 Single to a F450 Dually and now a 5500. F450 was super stable, 5500 takes it to a whole new level.
Feb-26-2023 07:58 AM
Yes but I have 2 extra tires transferring that braking force to the ground.
For the same reason I believe SRW trucks perform better in snow because they have less ground contact and dig/sink into the snow for better traction. DRW trucks have more ground contact and brake better. All my comments are from real encounters from the drivers seat not from trying to match part numbers or derived from what I think might happen.
Once you have experienced the performance first hand from the driver's seat, you no longer have to imagine what will happen.
Feb-26-2023 07:53 AM
greenno wrote:
Gdog I have a hard time believing that I should be running 35psi in my rear tires.
I could probably drop the front a bit more but I'm thinking not 15psi.
I have pretty even wear across the tire tread so I know I'm close to having a flat surface on the road.
Side treads as well as the centers were about the same so it's not crowning.
