EcoBoost problems on the Horizon...:?
The_Texan
Ford has a problem
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
66 REPLIES 66
mich800
Carrera man wrote:
carringb wrote:
Carrera man wrote:
Two people suing and a 100 complaints out of how many thousands of Ecoboost motors? Ridiculous.
3. Jeesh. way to down play the statistics. That's 50% higher than what you reported!!!
๐Ÿ˜‰
Your right it is three. I may have to sell all of my Ford stock tomorrow LOL!
Actually the statistics are amusing. Per the article, three drivers are suing Ford. Next paragraph, two of them are married. Maybe if they had driving age kids they could have brought it to class action status.
hone_eagle
markandkim wrote:
You got to know, when you ask a little engine to do what they are asking there are going to be major problems. just follow the # 1 rule; There is no substitute for cubic inches. Remember when you daddy and your brother told you that? It still stands today, even with todays modern technology.
Yup heard that right after WW1 ,when they went from 25 to 15 litre engines.
2005 Volvo 670 singled freedomline 12 speed
Newmar 34rsks 2008
Hensley trailersaver TSLB2H
directlink brake controller
-when overkill is cheaper-
boogie_4wheel
thomasmnile wrote:
I don't completely understand the phenomena, but isn't this condensation formation issue caused by what's known as "venturi effect" in high humidity conditions, similar to what happens to a normally aspirated piston engine aircraft only ice forms in the aircraft engine's carburetor rather than liquid condensation? On an aircraft engine, there is a carburetor heat control that when activated, directs some engine exhaust into the intake air to heat it and prevent carburetor icing.
Just have to believe the fix shouldn't be elusive to Ford, since turbocharged engines have been around forever.................
Not sure on the venturi effect... I do know a thing about carbs icing up. I had the same issue on my '70 pickup in the winter when I was in college in northern Utah. Really cold and going over the mountain pass the carb would ice up and the throttle would stick. My remedy was to modulate the throttle a little bit every couple minutes to keep it broken free.
I read more on the EB awhile back about high-humidity being a cause or magnifier to this condensation/misfire issue. I still feel that loading these things once in awhile will reduce/eliminate the problem; it shouldn't happen and owners shouldn't need to go out and flog their vehicles from time to time. It is just like when all the diesels went to DPFs. City driving, extended idle times, short-cycling, all lead to plugged DPFs. The solution was to drive them to get the exhaust gas temps up and help burn the soot out. I still feel that if these were 'worked' every once in awhile, water would not collect in the IC.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
goducks10
nohurry wrote:
Ford was looking to the future in gas engine technology with the ecos, and I say kudos to them for that. When they came out in the truck application some said "Oh man, this is going to be interesting! It'll never hold up!" Etc. well, after three complete model years it has. I'm not surprised there are some issues with some components such as the inter-cooler, and Ford seems to be addressing them. For whatever reason, these 3 people think legal action is the way to go. We truly don't know their real motive. If it's to benefit the buying public by holding a companies feet to the fire to stand behind the product, then fine. There may be more to it though.
I'm not real old yet, but I'm certainly not young either, and I've owned all the brands in my time. I choose not to bash someone else's choice, but I sincerely hate to see any American company go down. I think we are smart enough to know that they wouldn't knowingly put out products or components that will fail in some way, but we should be confident that they'll stand behind them. If you don't think they will, simply vote with your wallet, and go elsewhere like Ricatic did. I said publicly in this forum that I didn't blame him. The Fords I have previously, and currently owned have been very good to me though, so I will stay with them until I have a reason (like some of you), to switch. Now if you'll excuse me, I have some blue Kool aid on ice I need to get to (Goes good with popcorn)!
My guess is that these few people have tried to get it fixed many times and are sick of driving with a reoccurring problem. I had the infamous tranny bump on my 10 F150 6spd. I was told after several visits to the dealer that they considered it normal and also that they had no idea why this normal problem existed. And to just drive it and if something broke or malfunctioned enough that since I had a warranty it would get fixed. So in a nut shell just drive it till it breaks so then they will know what is causing the problem. Just go to any F150 forum and you can read about several common problems that have no fix. That lack of competency is why after years of being a Ford guy jumped to a Ram. I may go through the same thing with Ram at some day but I gave Ford a chance and wasn't happy with the results.
markandkim
Retired Navy
2020 Ram 2500 Bighorn 6.7L
2014 Crossroads Zinger 27RL
2022 Grand Design Reflection 315RLTS
nohurry
Carl
2007 National RV, Sea Breeze
thomasmnile
boogie_4wheel wrote:
skipnchar wrote:
The "problem" is not new and it's so far anyway been only a tiny fraction of the total built.
Isn't the "problem" that condensation is forming in the intercooler, and as drivers accelerate the intake draws in a tiny bit of water and causes a misfire, and the ECM may panic and go to limp mode?! Yeah, this has been floating around on the internet for awhile.
Simple fix for this, don't short-cycle the engines. Just like when everyone says don't idle an engine during long term storage to 'circulate fluids', or don't drive diesels on short trips that don't get them up to operating temperature.
If the 3.5L Ecoboost was a non-IC design, there would be less (if any) places for water to accumulate and cause this issue. I'd bet money that skipnchar will never have this issue with his truck because he uses it to tow, gets it hot, and that will keep the water from accumulating.
I would also bet that this issue begins to appear on the 2.0L and other EB engines that have ICs that are operated in the same conditions as I've mentioned above.
With that said, the wife and I are still planning on purchasing a 2.0L Ecoboost equipped Ford Escape later this year to replace her '05 Escape 3.0L.
itguy08
Wow, talk about a confoluted and baseless lawsuit. There are 2 versions of the EB 3.5, one for the cars/CUV's and one for the F150
I've got an early build 2010 SHO with the 3.5EB. At 55k and it's had the 2 symptoms in the lawsuit: the pinging/surging and the lack of power.
The known issues are:
1. Pinging/surging - affects early build Ecoboosts. For the knock sensor, Ford only used vinyl tape/shrinkwrap on the knock sensor wires. They ran next to an engine part (head I believe) and after 20k or so would chafe and cause the knock sensor readings to go crazy. Knock Sensor Chafing It was fixed in later builds (and with the replacement parts) by using loom encasing the wires. I believe in later (2011+) engines they rerouted the wire completely. Dealer fixed this without incident.
2. Cutout - This affects not only the EB 3.5's but a few others that use the 6F transmission. Transmission range sensor goes bad and confuses the car that you are in 1, 2, 3 or R and it goes into limp mode to protect itself. Ford has a TSB out for it and again, fixed by the dealer without issue. There are also trans mods if you are getting slipping and those only apply to the 6F55 if you are in a certain build date.
The F150 had an oversized intercooler. Ford has a fix and those affected have been getting their trucks fixed.
You buy the first year of anything and there are bound to be problems. None of the issues with mine make me enjoy it less - love the car. Maybe being in IT makes me be more understanding (same deal with V1.0 software)?
Learjet
Ford just needs a better intercooler on the earlier trucks.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
boogie_4wheel
Honda EU3000I Genny
Ric_Flair
2013 GMC 3500 DRW 4x4 SLT Duramax
2013 Road Warrior 415 Toy Hauler
2013 Kawasaki 4010 Mule
mrkoje
Steeljag wrote:
I've only had mine for a short period of time and have not experienced a problem. If there is a issue, I would like to think (hope) Ford will address it, and do the right thing for the owners.
I would hate to think I left Toyota for a lemon!
That's what the Ford 6.0l crowd has been thinking for the better part of a decade and still nothing! :B
RAPTOR 300MP
RAM 3500 MEGA CTD 4X4
skipnchar
The "problem" is not new and it's so far anyway been only a tiny fraction of the total built. Some have been purchased back from owners who then have a choice of another Ecoboost or another Ford Engine or take the money elsewhere. 34,000 on mine right now with no signs of any problems. It will have to show itself before I reach the end of my warranty (that's another 66,000 miles) ๐Ÿ™‚
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
Grit_dog
Navigator
Navigator
Wow, Well those of you that are going to burn your truck cuz Ferd sux so bad are about as retarded as someone suing because the truck broke down!
What happened to "glad this is under warranty, will take it in and get fixed for free"? Now it's "truck died, call the lawyer."
Heck I dont even like Fords (as much as the other 2)and I wouldnt say they suck. Have drove the******out of most every model year since the early 90's (company trucks) and just like any other brand some were good, couple were real nice and had 2 lemons. Not true lemon law but just more issues than should have.
Guess what, same thing with GM's and Dodges.
Next will be the guy that's suing them b!tching about how expensive new trucks are! Here's your sign!
fla-gypsy
Don't the ankle biters always go after the big dog?
