โSep-09-2020 12:03 PM
โSep-13-2020 10:34 AM
โSep-13-2020 10:24 AM
โSep-12-2020 11:49 PM
pianotuna wrote:Bert the Welder wrote:
https://sites.psu.edu/siowfa15/2015/09/18/is-driving-faster-safer/ .
Mark Twain,
There are liars, **** liars, and statistics.
One can cherry pick a data set to prove just about anything you want.
โSep-12-2020 11:42 PM
noteven wrote:Bert the Welder wrote:jimh425 wrote:JRscooby wrote:
Let's see, 85-62 is 23. Is it your opinion that most drivers can not miss a stopped car on a 4 lane road when driving 23 MPH? And the fault is the slow drivers?
Itโs not about fault. Itโs about increasing the chance of being in an accident.
According to state and federal studies, drivers that are driving significantly below the average speed are the ones that are most likely to get involved in an accident. Studies show that the most accidents occur when the driver is driving at 10 mph slower than the speed limit. So someone going 45 in a 55 has a bigger chance of getting into an accident than someone driving at 65-70 mph.
The main problem on roads that causes accidents is the differences in speed, rather than speed itself. While some people are going faster than other, some go slower which causes the traffic to flow unevenly. If the speeds limits are raised to comply with the actual travel speeds, the roads become safer, because the traffic now flows more evenly and people start going to the same speeds. This actually shows that drivers are not affected by the speed limits that much, but rather slow drivers. The National Highway Traffic Safety Administration (NHTSA) Says that only 30% of the accidents that are fatal are accidents in which the driver was speeding. This does not mean that the speeding actually is the cause of the accident. A study conducted by the Florida Department of Transportation says that accidents that were caused by speeding is actually 2.2%. This shows that if people drive faster all together it is actually safer than driving slow.
This is of zero surprise to me. Additionally, people driving too slow cause frustration for others resulting in loss of attention and more aggressive driving, particularly on single lane roads. Also, when driving faster, IMO, you pay even more attention and are more focused on what's going on around you. Poor road way design contribute to this with merging in on the left, turn lanes on the left side of highways and zero enforcement of not using the left lane for traveling.
And if yo do want to go slow, then there's nothing wrong with that. Adjust your route or at least have the courtesy to pull over. Absolutely loved seeing the signs in WA that stated you must pull off if you have more then 5 vehicles behind you. And they even provide short, right side slow down lanes so you can, safely. Bloodee brilliant.
Now Bert if we could just edumacate western Canadian drivers that where "passing lanes" are built on 2 lane routes, you don't floor it to 140 klicks so the line of 30 eleventeen vehicles that has been following you for an hour now cannot safely pass...
โSep-12-2020 01:54 PM
noteven wrote:
What I notice about 80mph speed limits is pretty much no one is speeding.
Where's the revenue opportunity in that?
โSep-11-2020 12:24 PM
โSep-11-2020 08:48 AM
โSep-11-2020 08:45 AM
โSep-11-2020 05:56 AM
โSep-10-2020 08:53 PM
โSep-10-2020 04:32 PM
StirCrazy wrote:KD4UPL wrote:
You have to be careful telling people they should get a diesel because it will help them slow down better. This is not at all true. A diesel engine has less engine braking then a gas engine.
All new turbo diesels have them in one form or another and have had them for quite a few years. weather it is by use of a varable vane turbo or a true exhaust brake, no gas engine has close to the engine braking power of the moderen disels.
Steve
โSep-10-2020 03:30 PM
Kayteg1 wrote:
When I drive with speed limit, I got sleepy. Is that safe?
โSep-10-2020 02:35 PM
โSep-10-2020 02:12 PM
JimK-NY wrote:
The Montana speed limit on open Interstates might be up to 80 mph, daylight driving only, but that is for cars, Suvs, light trucks. Heavy trucks are restricted to a max of 65 mph.
No way am I going to drive my truck camper at 80 or even past 70. When I upgraded to Rickson 19.5 wheels and Firestones, the max speed rating for the Firestones was 70.
