โSep-09-2020 04:56 PM
โSep-13-2020 02:46 PM
brianosaur wrote:
NEVER, ever, leave the city water on if you are not physically AT the camper and not asleep.
If you ever have a plumbing leak, or leave the tap running unknowingly, you may end up with a massive flood that will total out the rv.
Best bet is to always fill the fresh tank and close off the city water. Use fresh tank and it's pump when you need water.
Turn the fresh pump off when you leave your campsite.
Fresh tank can only run for so long and hopefully would run out before any tanks filled up with a running tap.
...dont ask me how I know.
โSep-12-2020 10:07 AM
โSep-12-2020 08:26 AM
โSep-10-2020 08:59 AM
โSep-10-2020 04:21 AM
Family-of-five wrote:
what do you use to test the power?
โSep-10-2020 02:57 AM
โSep-09-2020 07:42 PM
Hello friends This weekend will be out first time out in our new open range light 31bhs. I only have 15 amp to it in the driveway to keep the battery charged and run lights . just wondering what to check for after hooking up to 50 amps. I know to test the water heater on lp and electric.Look for leaks underneath.Test both ac units and furnace.Can you offer some small things I might overlook?
โSep-09-2020 07:36 PM
If you have not packed the wheel bearings in the last year, do so. Carefully check tires for air maximum air pressure, cracks etc. Make sure battery water is filled up, check for any battery post, cables for corrison.
โSep-09-2020 06:34 PM
โSep-09-2020 05:29 PM
โSep-09-2020 05:27 PM
โSep-09-2020 05:10 PM
